My first post here so excuse the sensational thread title, but I hear that some top monitor manufacturers are lining their cabinet walls with 2" thick latex.
Does anyone have any idea where I can source this in the UK? Or is it better to buy something like latex roofing sealant and pour it into the cabinet. The cab is 4 cu.ft and any help would be greatly apreciated. |
#2 |
Sorry, Can't help you sourcing it in GB.
2" is ungodly thick for latex, I use it for monster making at halloween and it lays up about 1/32" - 1/16" per coat. I pay ~$45 USD per gallon. At 2" thick I would have to sell my car to pay for that amount of laytex. Perhaps they were just sealing the joints with latex? Try sourcing some mobile home roofing repair material. Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 "I fired up the prototype. Literally." The Prophet Pass. |
#3 |
Are you sure it's rubber and not Bitumen?
Now, that's much easier to come by!! Self adhesive bitumen dampening Useful PDF Cheers, Martin. |
#4 |
You can get it from here
http://www.cfsnet.co.uk/acatalog/CFS...ubber_163.html You'll also need thixotropic gel too unless you have some kind of mould or it'll just run down whatever you apply it too and pool unless you use loads of thin coats. It's really stinks too BTW. |
#5 |
Many thanks for that link - I'll sort that out on Monday.
It's definately a 2" thick layer that's applied to all walls as far as I understand it. Don't Westlake do a similar thing? |
#6 |
Do you know what it does music wise?
#7 |
Bitumen is probably a safer and cheaper bet. Tested and proven.
You can buy it in liquid form for roofing I think and can pour and paint it thickly onto the walls of the cabinet. http://users.skynet.be/accupulse/manger_head.html |
| Rubber Surrounds Hardening With Age | PB2 | Multi-Way | 37 | 16th February 2011 02:00 PM |
| How do I get rid of that rubber smell? | grimberg | Everything Else | 0 | 31st July 2008 09:27 PM |
| Notch filter resistor values/latex paint | jay_ess | Full Range | 5 | 27th March 2007 02:35 PM |
| punctured rubber surround | alvinlim | Multi-Way | 9 | 3rd April 2006 04:37 AM |
| SME 3009 rubber | turntableKid | Analogue Source | 2 | 14th October 2004 04:02 AM |
| Page generated in 0.10518 seconds (66.39% PHP - 33.61% MySQL) with 10 queries |
