Old 1st March 2007, 05:12 PM   #1
murat is offline murat  United States
murat's Avatar
Default bedding comfort foam for absorption
I am using my AR speakers about 3 feet’s away from room corners and sick of “thin” mid-bass. This should be the famous 100 Hz dip. No, I don’t have SPL meter.
When I put the speakers close to the corners, bass becomes much better but overall sound becomes less clear, less transparent. As far as I know this is due to small front baffle and reflections from back and side walls.
Now, what would happen if I put the speakers to the corners and cover the walls at the corners with reasonably wide bedding comfort foam, extending more than a yard both on the back and front wall? This stuff also has some corrugation on one side. Would it make considerable difference? Since I want to use wide sheets I don’t want to spend on acoustic material – they don’t “look” much different anyway. Any idea??
Old 1st March 2007, 05:54 PM   #2
GM is offline GM  United States
GM's Avatar
Greets!
Bedding foam is typically closed cell and you need open cell for best results. A better solution is to add baffle extensions to bridge any gaps, then stuff the cavities with polyfil, fiberglass insulation or similar. Placing a shelf top on it and mass loading it with a heavy, bushy/leafy plant further improves performance and helps with any SAF issues.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Foam, thicker foam or Open Cell qguy Subwoofers 4 11th March 2007 07:06 PM
Foam cylinders for bass absorption xyrium Everything Else 0 21st February 2006 10:58 AM
Speaker damping: Foam or expanding foam akunec Multi-Way 2 16th September 2005 06:26 PM
Absorption coefficient The Dudster Multi-Way 5 19th March 2004 04:23 PM
dielectric absorption Bernhard Parts 3 20th January 2004 12:17 PM
Page generated in 0.07414 seconds (68.06% PHP - 31.94% MySQL) with 10 queries
