Old 28th February 2007, 09:37 PM   #1
ReidK is offline ReidK  United States
Default Removing woofer from an Alesis Monitor One
I recently picked up a pair of non-functioning Alesis Monitor One speakers (for free). The woofer frames are covered with some sort of rubber ring so that the screws are not accessible. Before I go gouging them up, does anyone know if there's a "right" way to remove these? A pic of the speakers can be seen here.
Thanks for any advice.
Reid
Old 28th February 2007, 09:50 PM   #2
pinkmouse's Avatar
Try heating gently with a hot air gun set on low. Oh, and protect the tweeter whist you work.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 1st March 2007, 05:27 AM   #3
Thanks for replying. Is there an adhesive that gets softened by the heat?
Reid
Old 1st March 2007, 09:28 AM   #4
pinkmouse's Avatar
A lot of them. It may not work, but it's a good non-destructive start.
Al
Old 1st March 2007, 03:22 PM   #5
farl is offline farl  United Arab Emirates
i have the same speaker but the latest model 'coz it a little bit different from your picture. The rubber ring felll down some time ago, and the glue that they are using is like a rubber cement or rubber glue. I think you can just removed it slowly by a flat screw driver.
Woofer protection for small monitor Mos Fetish Multi-Way 4 26th April 2009 08:39 PM
fixing a crack in NS-10M monitor woofer gilwe Multi-Way 36 19th September 2008 01:29 PM
Alesis M1 amps w/ 4ohm woofer AJinFLA Multi-Way 1 12th May 2005 06:04 PM
Removing air leaks around the woofer Wingfeather Subwoofers 3 21st April 2004 07:03 PM
Page generated in 0.08910 seconds (73.61% PHP - 26.39% MySQL) with 10 queries
