diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   What creates the impedance peaks in ported cabinet? (http://www.diyaudio.com/forums/multi-way/97103-creates-impedance-peaks-ported-cabinet.html)
teemuk 26th February 2007 07:36 PM
A ported cabinet has two peaks in it's impedance plot:
http://www.audioholics.com/productre...age001_000.gif
As the lumped model of a ported speaker cabinet consists of parallel and series resonant circuits (http://www.audioholics.com/productre...p_image002.gif) I’m a bit clueless how these two peaks are actually created. A parallel resonant circuit creates a peak with “gain” but the peak from the series resonant circuit should have a “negative gain”. Are these two peaks just overlapping or is something else happening here?
Svante 26th February 2007 09:01 PM
Re: What creates the impedance peaks in ported cabinet?
Lces and Cmes results in the driver free air resonance fs.
Lceb and Cmep results in the helmholtz resonance fh.
At fh, the series circuit has a minimum, and so has the impedance of the entire circuit.
Above fh the series circuit is inductive and adds to Lces, two inductors in parallel resuts in a lower inductance and a resonance frequency higher than fs. This resonance is the higher of the two peaks in the impedance curve.
Below fh the series circuit is capacitive and adds to Cmes, two capacitors parallel resuts in a higher capcitance and a resonance frequency lower than fs. This resonance is the lower of the two peaks in the impedance curve.
Resources saved on this page: MySQL 18.75%
