I have an RTA program called SpectraPlus on my laptop. I did some messing around, using a Radio Shack digital SPL meter and a Stereophile test CD. Now I'd like to get a better pickup.
What inexpensive microphone (under $40.00?) could I buy that would plug directly into the laptop's internal sound card (mini-jack), and does not require calibration for reasonable results? I'll also need some good test tones. I did a search but I didn't find exactly what I want. Thanks.
Dan |
#2 |
You have a few options here.
If you want something fairly cheap then a Behringer ECM8000 is a good choice - a friend used to use one for room corrections to good effect. You can pick one up for under £40, here's a link to the Behringer website: Behringer - ECM8000 Unfortunately you'll need phantom power and a preamp to use this with your laptop/PC. I've just bought some Panasonic electret capsule inserts that I hope to make a measurement mic. from and if you're technically minded I suggest you invest some time and (not much) money and do the same. If you do a google search for "Panasonic wm-61a" you'll get plenty of info on the capsule, how to modify it to get lower distortion (conversion from common source to source follower) and circuit diagrams for an amplifier. I'm no expert on microphones, however I think the only type that you can plug directly into you laptop/PC are dynamic types that don't require power - I think these typically have much poorer frequency response than electret. I hope this helps!?
...if it ain't broke don't fix it - make it BETTER! |
#3 |
The virtually no cost microphone solution is a Panasonic WM-61A electret capsule at $2 a piece. The mic needs a battery and a couple of resistors for power feeding, as described here: Powering Microphones
The Behringer ECM-8000 is an equivalent performance ready-made mic at around $40-50. Itis normally used with a pre-amp with 48V phantom power. I do not know if a simple passive power feed of this one is possible. SveinB |
#4 |
I'd listen to this guy - he clearly knows what he's talking about
#5 |
cheers and good luck T.J.
we all have problems only some people have more than most.... long live the Magyar (Hungarians) in the world! |
#6 |
If you want to make precise measurements you obviously need a calibrated mic, preferably a B&K $$$.
For DIY purpose you can probably get close enough without calibration. Both the Panasonic and the Behringer usually have a small hump of a couple of dB above 10KHz. Below 10K the errors in amplitude seem to be negligible. Generic calibration files can be found which may compensate [most of] the small errors. The mounting of the mike i a narrow neck is important to maintain its frequency response. The picture below shows a canibalized 3$ mike which has been rebuilt with a VM-61A capsule and battery power. |
#7 |
I highly recommend getting a Panasonic capsule thats been calibrated. I got it done for about $35. You can build a preamp for it for another $30. With this setup you can get very accurate response curve down to ~300hz in an average room.
#8 | |
I once build a microphone after a Klang+Ton article. It uses a relatively cheap capsule with good linearity. Regards Jürgen |
#9 | |
Connect a minijack-to-minijack cable from PC output to mic input, and set low volume and low mic gain. Run an FR curve, and prepare the necessary calibration file to make it flat from 20-20K. You probably only need to do this to the nearest dB for indicative measurements, and ignore phase correction. SveinB. |
#10 | |
1) One external USB sound card with separate line input (not with only one input shared between mic and line). There are two inexpensive of Creative. One is the “Sound Blaster Live! 24bit” about 50$ and the other (recommended from me) is the new “Sound Blaster Connect” about 57€. Avoid PCMCIA cards because they have same inputs as your Laptop and are expensive. 2) One Behringer ECM8000 electret condenser mic about 55€. 3) One inexpensive mic preamplifier with a supply at least of 15Volts for this microphone about 60€. Or a DIY single channel microphone preamplifier such that i have made from my own (i enclose one photo of this, but take a look and in the thread “Speaker Workshop?” in this forum where you will find one relative reply from me) cost of 50€ but with unsurpassed sound quality from every inexpensive mixer on the market. The sum is about 160 - 170€ for all these above, and it should spend him if you really want your measurements to be compared with those that give luxury instruments on the market. The cheapest such that i could find was a USB data acquisition 12bit device of National Instruments about 600€. Regards Fotios Anagnostou |
| Mike's Proposed MTM | Mike C | Multi-Way | 34 | 5th December 2007 09:33 PM |
| Mike's MTM - Tweeter Choice | Mike C | Multi-Way | 5 | 2nd November 2007 09:02 AM |
| Mike's Project - MTM? | Mike C | Multi-Way | 1 | 9th January 2007 10:09 AM |
| Measurement mike | lndm | Everything Else | 6 | 29th March 2006 08:25 PM |
| cb mike jacks-supplier? | karma | Everything Else | 2 | 6th August 2004 05:04 PM |
| Page generated in 0.12951 seconds (88.18% PHP - 11.82% MySQL) with 11 queries |
