Hey y'all, I'm only mildly furious right now. I spend around a month designing these new filters for my speaker project, and the tweeter doesn't work on either! I cannot figure it out for the life of me. All I can tell you is that it's a 4th order Butterworth slope on the tweeter, and a 3rd order Butterworth slope on the woofers. Most importantly, I was doing some localized testing to see what was happening, and I found that the tweeters themselves are fine, and are still fine when given power at the terminal. However, when I applied power to the first inductor location, the power dropped literally about half, and when I applied same power to the 2nd inductor location, the power was nearly non-existent. The woofers work fine though, so I cannot figure it out at all. The only guess I have is that the inductors are too close together (note the tape I put so that they wouldn't touch), but I dunno. Help!
-Dave Pics of the x-over if that will help, keep in mind this is my first time with a PCB and etching. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#2 |
Hi lemans23,
I don't see on your pcb a + or - terminal that must the same for tweeter and woofer. With regards, sigurd. |
#3 |
No, there are. On the first picture, notice the little sticks of metal. I didn't have any x-over posts, so I just used jumper wire. The ones on the right are the end terminal, and the ones closest on the left are for the tweeter, and below them are the woofer. Seen from the underside, the fourth from the bottom picture shows the right right holes as the end terminals, and the far left ones for the tweeter closest, and the woofer ones furthest away.
#4 |
Help!
#5 |
1) check your pcb connections with an ohmeter to make sure the pcb matches the schematic - I don't know how many times I have messed up by forgetting whether I'm looking at the top side or the bottom.
2) make sure that you have done a good job of stripping the varnish off of the wires on the inductors before soldering to the board 3) post a schematic of the x-over 4) if all else fails, put it away for 24 hours and then look at it with a fresh set of eyes. |
#6 |
Schematic may help
could you have reversed components seen from amp side it should be .... cap---inductor---cap---inductor what are those resistors I really dont like xo on printboard like that, easy to make mistakes - also cobberlines looks awfully thin, but that should not be your problem Furthermore, all inductors should not face the same, but should all be oriented differently, at least the two in the midle |
#7 |
![]() That's the schematic. So what exactly should I be looking for with checking the impedance at the inductors? The traces are .4 ohms (I don't know if that's good or bad). What do you mean by stripping varnish? I've never done that before and I always use the same inductors (18awg Jantzen). The resistors are as follows Tweeter: Rp1=1.5, Rp2=30 Woofers: Rp1=1.2, Rp2=10 And I'm pretty sure that I wired it correctly because power goes through the entire circuit, it only starts dropping off on the tweeter side. I really appreciate any help you guys give me. |
#8 |
Okay, I'm heading off to bed. Thanks for the help again, and I'll check this thread tomorrow.
#9 |
again, check the pcb against the circuit with an ohmeter. Make sure you don't have C1/C2 or L1/L2 swapped. The inductors should measure less ohm resistance at DC - compare against the specs.
The varnish is the insulation on the wire used to form the inductors - it needs to be stripped off of the wire with fine sandpaper to expose the bare copper in order to make a solder joint. Some components come with pre-stripped and tinned leads so this isn't always necessary. Why do you have a pad on both the tweeter and woofer? Seems like a waste of power. For the woofers you could remover Rp2 and replace Rp1 with a piece of wire, then adjust the values of the resistors for the tweeter to balance levels. |
#10 |
I think the tweeter ground is missing on the board.
In the diagram, the "-" of the input, tweeter and woofer are connected together. Unless you have a wire soldered on the top side somewhere, the tweeter connection is missing. OT: why is there an L-pad on both the woofer and the tweeter? |
| Can this crossover work in my speakers ? | kyu | Multi-Way | 5 | 5th September 2008 10:28 AM |
| Tried assembling my own crossover...why didn't it work? | PoorSound | Multi-Way | 5 | 16th February 2008 07:02 PM |
| Gaincline Bi-Amp / Active Crossover - work in progress | gainphile | Chip Amps | 10 | 5th January 2008 11:35 PM |
| Looking for 6.5"s and tweets | xplod1236 | Car Audio | 29 | 23rd September 2006 04:31 AM |
| have a speaker design- need crossover- will this work? | trespasser_guy | Multi-Way | 1 | 26th August 2002 05:23 AM |
| Page generated in 0.13098 seconds (82.91% PHP - 17.09% MySQL) with 10 queries |
