I'm trying to make a smooth spiral that @ some point may be fairly tight (min 8" diameter). I haven't been able to find flexible plywood locally in Pittsburgh, so I'm thinking about using some 1/8 hardboard and laminating it.
Has anyone tried steaming and bending the stuff?
Is there a better similarly price alternative? Thanks.
Steam bending can be done to a number of species, including ash and white oak. However, it doesn't work very well on kiln-dried wood - you want "green" (unseasoned) wood with a reasonably high moisture content. Here's a link to some steam-bending information.
Alternatively, if you have the tools or can find someone to rip it into thin strips for you, you can stack-laminate many species - ash works well for this too. Basically you epoxy together a lot of thin (1/16"-1/8", depending on radius) strips and clamp them to a form while the glue sets. If you do this, you can make forms out of MDF; wax them so the epoxy doesn't stick to them.
Regards.
Aengus
Regards.
Aengus
Thanks for your suggestions guys - this is very helpful.
Seems like I'll need to find a place locally to get some thin green cuts as well as the void-free baltic I'll need for the rest of the project. When I checked a few days ago Lowes wasn't exactly loaded with solid woods at the thickness I need.
- easiest wood to steam bend for horn?
