#921 | |
Deep dado for the front is working well. I install the front panel in 2 steps. The first panel is 230mm wide and glued to subfront. Then the side panel/top bottom panel is machined to leave only the outside 2 veneers of the plywood and a wider panel is glued into that space covering most of the ply end. veneering over the front now with only 2 plys(only outside veneer of the remaining 2 is end grain ) facing forward seems to work out nicely with no surprises. Also consider building the cabinets so veneer will go opposite grain orientation of the plywood. this also helps with rabbet mitered top and bottom corners because the mitre will be cut "with the grain" on the ply. The movement of the 2 veneers are not additive Bondo is used on plywood end as well. Butt joint or rabbet with 1/4" space and fill with bondo and trim the corner square. Never done it myself but read many have with good results. Hardwood corners work and 1/4 thick edging is good for corners and front. For me at this point for future builds it will go Rabbet/mite on top/bottom corners and 2 step front panel.. |
#922 | |
John |
#923 |
The small speaker has a 45 deg mitre with a rabbet. The sides and top are dado'd so the pack panel fit in, hence, you dont see the full rabbet on corners..
One board is cut complete with 45 deg v router bit and the other requires a straight grooved cut first, then a 45 mitre. I used 4mm mdf on the front to cover end grain and this worked good. The Elsinore is clamped with dodo joints and care has to be taken to keep it all square because the clamps put forces in unwanted directions. Top and bottom is put on after the rest is set. Hope this helps, that all for related pics Have a happy build, Joel |
#924 |
Hi Joel and others... RE: ROUND WAVEGUIDES & FRONT PANEL CONSTRUCTION: It is apparent that the Front Panel should be one piece from now on for those making new Elsinores I have changed the Construction Page on the website to reflect that. Both variations are shown. ![]() The older design is still there for those who prefer it. BUT MY SUGGESTION IS NOW TO USE ROUND WAVEGUIDE (a la Joel's). If unable to make your own, then by all means contact Joel and buy them from him. The square Waveguides I have here will be reserved for those with existing Elsinores that needs upgrading. For Joel: I have shown the cut-out on the above drawing as 150mm diameter - but what diameter are you actually using. Does the 150mm round aluminium end up a slightly less diameter and thus an exact 150mm cut-out will be perfect? Cheers, Joe R.
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" |
#925 |
Firstly I want to Thank Joe, for the great gift! Speakers sound fantastic, after B & W 601 it is such a breathe
Most surprising was bass response, which I thought impossible to archive without subwoofer. Highs are not as aggressive compared to other speakers, but all in all it is very natural speakers, even in my living room with laminate floor and not many furniture, while it is not big. Everything seems to sound right, from m jackson, apocalyptica, rihanna, a. bochelli, to die for, judas priest, erasure, dire straits and even old recordings from russia and bulgaria. Currently they not finished completely: crossovers are lying on the floor and no vaweguide installed as yet, but sound is already the pure joy. More likely this is the speakers that I grew old with Maybe I will do a few more speaker designs in order to satisfy my DIY Crutch and curiosity with TQWP like:TQWP - Tapered Quarter Wave Pipes or TQWP [English] , TQWP. Open baffle like this if I manage to source saba drivers for Endorphine project: Endorphine from Kingston Kitchen and finally spheric speakers since it is so much noise about spheric design on the inet and forums something like: assembly.nm.ru: Сферические колонки из ДСП or as an inspiration -http://www.audioholics.com/reviews/speakers/floorstanding/proclaim-audioworks-dmt-100. Once again thumbs up for Joe!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
#926 | ||
Joe, I have to say I'm very pleased to see my cabinets your website. ![]() Working hard on the cabs is a pleasure when knowing how amazing the final sound is going to be.. Quote:
I'm also getting made 8 CNC'd flushing templates the same as the one on post 905 in picture 2. The material will be particle board and can be used many times so one could be shared. If your not sinking the woofers then it's not needed. If everything works out as planned the price will be $60 Quote:
FOR ANYONE THAT WOULD LIKE TO HEAR THE ELSINORE'S WITHIN DRIVING DISTANCE YOU CAN DROP IN WITH YOUR OWN AMPS. SEND ME AN EMAIL TO SET IT UP.. I HAVE A DEDICATED LISTENING ROOM THAT YOU CAN LISTEN FOR A FEW HOURS. FOR US PEOPLE YOU MIGHT JUST FIND THAT CROSSING THE BORDER IS WORTH IT Joel |
#927 |
1399.8 miles from Seminole FL to Courtice Ontario (23 hours, 56 minutes).
Hmmm, might still be worth it.
-- jk -- |
#928 | ||
#929 |
Best part about this effort is the chance to acquire new tools and new skills.
Spent some quality time with my new router this weekend. I have not worked a lot with one in the past, but let me tell you, it is one VERY cool and very versatile tool! Decided to make jigs for the main brace and sub-front panel. Learned how to straighten rough cut lumber, made up a couple of templates and finish cut the jigs this morning. Turned out pretty good. A couple mistakes, but nothing that cannot be fixed. One thing is for sure, I am feeling MUCH more comfortable using the router. On to straightening the rough-cut cabinet material and routing the main brace and sub-front panel. What a great project this has turned out to be!
-- jk -- |
#930 |
If it was January it would make a lot of sense, really.
My religion is the golden rule. The only time it's forsaken me is when I've forsaken it first. |
| "Proac 2.5 clone" or "Elsinore project" | Joel Wesseling | Multi-Way | 10 | 26th May 2011 05:51 AM |
| A thread to post your "project files" | critofur | Multi-Way | 10 | 21st March 2008 12:50 PM |
| "compact loudspeaker factory visit from "magico mini" thread | Nanook | Multi-Way | 2 | 4th January 2008 07:30 AM |
| The "Really simple and cheap speaker designs for the newbie!" thread. | Spasticteapot | Multi-Way | 5 | 19th March 2006 04:16 AM |
