The "Elsinore Project" Thread
Old 14th May 2011, 02:27 AM   #861
Joel Wesseling is offline Joel Wesseling  Canada
Can we see a closeup of where the waveguide meets the tweeter?
At the front? I dont have the black ones. there all shipped. I can show the wood ones(taped in place) that I have in other cabs that are now MK5
Mk5 sounds great.. Great job Joe
Friend showed up and immediately noticed more revealing and detailed treble
Bass is better across the range and midrange clean and the main thing(balance) I loved about them seems to remain.
All first impressions after 4 hours
Waveguides
I"m keeping rough track of the takers.. I think its close to a go
Best to email me at neverenoughmusic@hotmail.com if you want a pair
I'll get the starting numbers and then post a final time fo anyone coming in a bit later..
Thanks for the comments on the speakers..
Joel
Old 14th May 2011, 01:16 PM   #862
Tried some a few wood species.
Lacewood close up
Old 14th May 2011, 11:50 PM   #863
jdkJake is offline jdkJake  United States
I think I can handle that.
I received the waveguides from Joel today. Wow, am i impressed! They turned out spectacular! They are quite substantial, more than I expected. The powercoat is first class and really lends a professional touch. Hat's off to Joel for the superior effort and outstanding turn-around/comms (Thanks again Joel).
In any case, here ya go:
-- jk --
Old 15th May 2011, 03:17 AM   #864
Joe Rasmussen is offline Joe Rasmussen  Australia
Joe Rasmussen's Avatar
They sure do!
Cheers, Joe R.
The "Elsinore Project" DIY Speaker System & DIY "Trans-Amp" - 40 Watt Transconductance Amp
- "Don't take anything I say as an affirmation, but as a question." Niels Bohr
Old 15th May 2011, 02:48 PM   #865
jea is offline jea  United States
jea's Avatar
Question for those who built a Elsinore center speaker. If the speaker is close to your tv don’t you need to use shielded speakers? If so how did you resolve that?
Thanks,
jea
Old 15th May 2011, 02:51 PM   #866
jea's Avatar
Originally Posted by mantraxl View Post
Same here, 3" pvc coupler (with center ridge ground down) from Lowes.
They make a fitting called a slip coupling. It already has the center ridge missing. Look in the plumber/pipefitting section.
jea
Old 15th May 2011, 02:55 PM   #867
Woody1911a1 is offline Woody1911a1  United States
Originally Posted by jea View Post
Question for those who built a Elsinore center speaker. If the speaker is close to your tv donít you need to use shielded speakers? If so how did you resolve that?
Thanks,
jea
only if your tv is a crt . plasma's lcd's etc not required .
cheers Woody
Old 15th May 2011, 03:04 PM   #868
jea's Avatar
cheers Woody
Thanks Wood!
Old 15th May 2011, 06:35 PM   #869
jea
Thanks. The plumbing slip couplings I found were a bit undersized. The 3" electrical coupler I got from home depot is ~3.5" ID (90mm ID) and 88mm in length. Once the center ridge is eliminate, it should be perfect. A 4 and 1/8 hole saw (105mm) will be just about right if not perfect for the outside diameter.
-- jk --
Old 23rd May 2011, 12:07 AM   #870
sooooooo , how are your elsinores sounding ?
i found this thread a couple months ago and knew that i had to build them
several major expenses got in the way , but i'm getting ready to order things and thought a bump was in order
cheers Woody
The "Elsinore Project" ThreadHide this!Advertise here!
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 05:51 AM
A thread to post your "project files" critofur Multi-Way 10 21st March 2008 12:50 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
