The "Elsinore Project" Thread
Old 25th April 2011, 02:17 AM   #841
Joel Wesseling is offline Joel Wesseling  Canada
jdkJake Looks great Joel!
Have you chosen a veneer yet?
Thanks. Working in the Filler is making more sense to me now.
Working on a pair with Walnut veneer and thin Walnut boards for the front.
Really liking this
That pair could end up with Keviziga that has some nice straight lines in it.
Many nice veneers. Hard to decide
Joel
Old 4th May 2011, 12:33 AM   #842
jdkJake is offline jdkJake  United States
Joel,
Are you attaching the waveguide to the tweeters or is everything held in by pressure (waveguide pressing back the tweeter into the cutout/stiffener)?
-- jk --
Old 4th May 2011, 02:31 AM   #843
Tweeter recessed and mounted to sub front panel
Waveguide independently mounted to subfront with screws clear of tweeter.
Have to get the tweeter recess right so 3mm projection either just touches tweeter face or slight gap? Probably slight gap is best?
Old 4th May 2011, 02:33 AM   #844
critofur is offline critofur  United States
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
Originally Posted by Joel Wesseling View Post
Some Waveguide fillers
Some one already mentioned it but think I'll try gluing in filler and then using filler around the edges. At this point I can level the the mdf and veneer over the front complete.
My fronts are 17.5 mm ply so have to recess Wg a little more into the sub front..
The tweeter looks to be significantly offset vertically to the waveguide in that photo, it it just stuck in roughly for a photo?
Critofur
http://www.ohmspeakers.com <- all the folks here are my friends
Old 4th May 2011, 02:49 AM   #845
Good Eye. The filler is not glued in position in that photo, I just let the filler sit there. On my other pair I have both fillers glued on - I put the tweeters in the recess and aligned waveguides over the tweeter, then placed the fillers over wg. Then I drew 3 scribe marks on the filler and cabinet so I could remove the components and glue in fillers..
Old 4th May 2011, 03:30 AM   #846
Joe Rasmussen is offline Joe Rasmussen  Australia
Joe Rasmussen's Avatar
I am sure that Joel wouldn't have made that mistake.
Cheers, Joe R.
The "Elsinore Project" DIY Speaker System & DIY "Trans-Amp" - 40 Watt Transconductance Amp
- "Don't take anything I say as an affirmation but as a question." Niels Bohr
Old 4th May 2011, 11:26 AM   #847
The &quot;Elsinore Project&quot; Thread
I would think you would want it to touch the face and leave no gap. Probably build a gasket out of felt or similar and use that to ensure a seal. Zaph did something similar for his TMM waveguide build.
-- jk --
Old 5th May 2011, 09:42 AM   #848
Time to reveal something:
The Elsinore Mk5 has an until now un-announced feature: Right now in my system I am running it with a Current Amplifier.
Yes, the Mk5 are compatible with current drive, and I do believe this is the only multi-way speaker system, DIY or otherwise, that may be so described.
Some may be aware that Nelson Pass made the F1 "transconductance" amplifier. This simply another way of saying it outputs current.
Normal amplifiers are of the "voltage"kind, this is 99.999% of all amplifiers out there. My memory of what the text book says is that we have a voltage interface when the insertion (the load) loss is no more than 1dB or less. The voltage amp tries to maintain voltage (regulate it) irrespective of the load in Ohms.
Typically this means that the voltage amp should have no more than 1/10th the output impedance of the rated load in Ohms. So for an 8 Ohm speaker the output impedance should not be higher than 0.8 Ohm and for a 4 Ohm speaker no more than 0.4 Ohm. These are simply rule of thumb, but you could get precise figures if you figured out what output Z would cause exactly 1dB voltage drop.
The "current" amplifier works just in reverse. While a "voltage" amp is defined by it low output impedance, the "current" amplifier is defined by it very high output impedance. Maybe we should use the same rule of thumb and say it should be at least 80 Ohm for an 8 Ohm speaker system, and similarly 40 Ohm for 4 Ohm.
The Nelson Pass F1 had an output impedance of 80 Ohm. The later F1J had about 50 Ohm. So you can see the picture.
I have built a current amplfier with well over 100 Ohm output impedance, indeed as configured right now is is closer to 200 Ohm than 100 Ohm.
And it works!
I am thinking about publishing the amp design on a suitable forum here on diyaudio.com - which one and when is not yet decided.
BTW, it sounds VERY GOOD!
Cheers, Joe R.
PS: IF ANYBODY LOCALLY WANTS TO DROP IN AND HEAR THIS - YOU WILL BE WELCOME!
Old 6th May 2011, 05:05 AM   #849
spoonted is offline spoonted  Australia
And it works!
I bet it does Joe and thanks for even contemplating sharing your hard earned work.
Still over the moon with the Elsinores by the way.
Cheers Paul
Old 7th May 2011, 11:24 PM   #850
For those Elsinore builders in North America, where did you source your port material? PVC or other material? Curious as to what worked and worked well.
Thanks!
-- jk --
The &quot;Elsinore Project&quot; ThreadHide this!Advertise here!
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 05:51 AM
A thread to post your "project files" critofur Multi-Way 10 21st March 2008 12:50 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
