The "Elsinore Project" Thread
Old 15th April 2011, 12:58 PM   #821
Joel Wesseling is offline Joel Wesseling  Canada
Sorry about that. Fat finger on the submit reply
ALUMINUM WAVEGUIDES
I received a few emails while I was figuring out the details but please email again if you want a pair and I will keep track of things now.
The price is based on min 10 for CNC and paint.
Have 2 comitments now. Thank's Ben and Matt from Alberta.
Sincerly, Joel
Old 15th April 2011, 01:45 PM   #822
Do the waveguides exactly match the mounting plate of the tweeter and does it have matching holes so that the WG and the tweeter are mounted with the 4 screws?
If so, that would be great.
How are the WG's finished? Are they black anodised?
The Waveguide is wider than the tweeter mounting plate.
The holes in the WG are halfway between the outer perimeter edge of the bottom recess and the outer perimeter of the WG.
The supplied wood screws are from Solen and designed for Diy speaker projects. They look like machine screws and have an alan head and recess perfectly in the holes.
The WG will screw into the sub front panel with new pilot holes. Screws go 18mm below WG.
Black Powder Coat
Hope this helps, Joel
Old 15th April 2011, 04:08 PM   #823
ABO is offline ABO  Netherlands
Originally Posted by tinitus View Post
btw, for the big ones I can really recommend toroids
can't do without those
Arent the coils supposed to be air cores?
Old 16th April 2011, 12:56 PM   #824
Talking with the CNC guy. He's keen on making a Hardwood Waveguide.
Going to take him a couple of round 1 inch pieces of Walnut. Probably only good for from scratch build. Dont know if it could crack later?
This was my initial Attraction.. See what happens..
Joel
Old 16th April 2011, 01:22 PM   #825
Joe Rasmussen is offline Joe Rasmussen  Australia
Joe Rasmussen's Avatar
The largest inductor I use 2 x 9mH in series, these do not have to be air cored, but the rest should be.
Cheers, Joe R.
The "Elsinore Project" DIY Speaker System & DIY "Trans-Amp" - 40 Watt Transconductance Amp
- "Don't take anything I say as an affirmation but as a question." Niels Bohr
Old 16th April 2011, 02:15 PM   #826
Joe,
Thanks for the reply. Perhaps you are willing to answer another question. It seems that half of the crossover really does not do any filtering. These parts seem to merely act as a load for the power amp. I am of course referring to strings L4-R2-C3, L5-R3-C4 and 10R-0,68u.
I have seen this before as optional for tube amps, but never before as standard part of the crossover.
Would you recommend using them for a high power, high feeback solid state amp? I am asking because these parts seem to contribute to the cost of the crossover significantly. Thst is not a problem per se, but I wouldn't want to waste my money.
Thanks, Lex
Old 16th April 2011, 02:24 PM   #827
Hi Lex
Just trust me, there are things happening here that are not obvious. Truth be told, I have been told not say too much.
Like I said a few messages back, just build them and enjoy them. I doubt if you will regret it.
Cheers, Joe R.
Old 16th April 2011, 10:51 PM   #828
WAVEGUIDE FILLER
What about using the existing felt and cut out the hole for the WG?
Use both pieces, one for back fill(or wood strips) to keep it flush
Tried it quickly with some left over. looks pretty good but imagine it with nice felt, veneered cabinet and accurate trimming..
Joel
Old 16th April 2011, 11:19 PM   #829
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
KEF used conjugate through many years
I'm not suggesting this is just that
looks like one is dealing with driver/box ressonance
and the other, well....?
might be 'killing' anything it 'sees' above the series inductor in front of it, maybe
Old 17th April 2011, 12:49 AM   #830
Good try... but no.
KEF used conjugate for a different reason. And if you look at the conjugate alone... that is simply a distraction.
I really can't say too much at this stage. If I may speak cryptically, think noise... and no, I don't think you will guess it. It is very left field - but audibly very obvious.
We know that at least one very high-end designer (very to extremely expensive speakers) who is aware of this, but he is clearly using a different approach to the same subject. So there may be other ways of dealing with it. He won't say, we won't say.
Just build it and enjoy it.
Cheers, Joe
The "Elsinore Project" ThreadHide this!Advertise here!
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 05:51 AM
A thread to post your "project files" critofur Multi-Way 10 21st March 2008 12:50 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
