The "Elsinore Project" Thread - Page 63 - diyAudio
Old 6th August 2010, 10:31 PM   #621
Joe Rasmussen's Avatar
Originally Posted by zdr View Post
I might have missed it, but I did not see any exact damping specs. Which material, which walls, sizes, etc. I saw some photos in this thread which led me to believe there is no heavy wall damping with bitumen like mass of any kind?
No bitumen or "heavy wall damping" as you say. The only damping is on the same page that shows wiring:
Elsinore Wiring
Cheers.
Joe R.
The "Elsinore Project" DIY Speaker System " & DIY "Trans-Amp" - 40 Watt Transconductance Amp
Soon: High Frequency Bias in Tube OPT - "Don't take anything I say as an affirmation but as a question."
Old 6th August 2010, 11:06 PM   #622
zdr is offline zdr  Belgium
zdr's Avatar
Thanks Joe, I am almost hooked
I don't have access to Dacron, but I used Sonofil from Intertechnik in the past which seems to have similar density. The problem is that it comes in only one thickness which is 40mm, so I will have some trouble making it thinner.
What about the quality of the tweeter cap? I am thinking of using inexpensive Audyn MKT. I know everyone seems to like expensive caps in series with tweeter, but I don't know how much this really matters in real life.
Old 7th August 2010, 07:47 AM   #623
CCU is offline CCU  Denmark
Send a message via MSN to CCU
Quallity caps in series DO matter. But who says they have to be expensive
tjek this out. Humble Homemade Hifi
I'm using Carity caps SA MKP. they only cost a fraction more than the Audyn caps your using and they are fantastik
Old 7th August 2010, 08:50 AM   #624
zdr's Avatar
CCU, thanks for that! I was really not prepared to spend ~120eur on two caps... I see that they even provide samples, so I will try that first.
Where do you buy them from?
Old 7th August 2010, 10:18 AM   #625
Originally Posted by CCU View Post
Quallity caps in series DO matter. But who says they have to be expensive...
I have been using ClarityCap ESA 0.22uF/630V as coupling caps in my tube amps and they are very nice indeed. Would also do pretty good in the Elsinores I suspect. While more expensive than SA they are still very good value.
Cheers.
Joe R.
Old 7th August 2010, 10:32 AM   #626
I buy them at HiFi DIY products and accessories - Welcome - gato-shop.com
They are the cheapest place i could find. They have fast and good service. Plus very cheap shipping(at least in Denmark)
Bonus info. The SA series is also used in Neeper's Perfection One speaker. that also says something about the quallity of the caps. Because they sound amazing
Old 7th August 2010, 10:39 AM   #627
Hmm. I am trying to think. Assuming the density is about right, the back three pieces should be double 40mm = 80mm layer. Using the weight as a guide that should weigh about 400gr and a bit - and no more than 500gr max?
I looked at the link you gave and you say 40mm thick, but the size is not shown and no weight. Otherwise I could have helped a bit more?
Cheers.
Joe R.
Old 7th August 2010, 12:07 PM   #628
zdr's Avatar
Cheers.
Joe R.
Here's the link. There used to be a datasheet for it, but cannot find it there anymore:
IT Speaker Shop - SONOFIL/W/SB | Damping :: Accessories and Miscellaneous ::
Old 7th August 2010, 12:17 PM   #629
zdr's Avatar
1000mmX350mmX40mm
Old 7th August 2010, 12:20 PM   #630
zdr's Avatar
Found the full specs, but there is no density info:
Intertechnik Dämmatten Sonofil SO/1/W (IT1343336) bei Trenkenchu & Stadler GbR
There is a link to pdf on the bottom.
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 06:51 AM
A thread to post your "project files" critofur Multi-Way 10 21st March 2008 01:50 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 08:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 05:16 AM
Copyright ©1999-2017 diyAudio
