The "Elsinore Project" Thread - Page 53 - diyAudio
Old 16th May 2009, 10:40 AM   #521
thanks, sounds good, ill keep researching amps to build and play around with.
cheers
Old 17th May 2009, 11:09 PM   #522
Joe Rasmussen's Avatar
MY COMPUTER CRASHED!!!
At least one person emailed me directly the morning my hard drive, only two months old, went belly-up in seconds. Lost record of all emails since February 15. Not able to reply as I don't have email addresses. Dar'n it!
So if anything got missed out and you got no reply... please resend correspondence
Joe R.
PS: Now setup FBackup 4.1 and backup every day. Not getting caught again.
The "Elsinore Project" DIY Speaker System " & DIY "Trans-Amp" - 40 Watt Transconductance Amp
Soon: High Frequency Bias in Tube OPT - "Don't take anything I say as an affirmation but as a question."
Old 17th May 2009, 11:13 PM   #523
Originally posted by beauistheman
can anyone suggest a nice diy amp that runs nicely with the elsinore speakers? Not only tube, but also in solidstate etc. I have no idea how these speakers respond to various amp types, so please inform me. Also, atm i would be looking at a relatively non expensive route as i intend to build an amp first, then later maybe the speakers, and further on another amp. But all comments welcome
The Elsinores were also developed with Tube Gainclones is mind, and here it is:
http://www.customanalogue.com/diytub...lone/index.htm
Joe R.
Old 17th May 2009, 11:30 PM   #524
danieljw's Avatar
Send a message via MSN to danieljw
Hi Joe,
I sent some comments about the Dc bias circuit, i have been listening to it for a while now....
seems to help at higher volumes in terms of clarity.
-Dan
Old 18th May 2009, 02:24 AM   #525
Originally posted by danieljw
Hi Joe,
-Dan
Hi Dan
Yes, I like what it does. But my system - and I hate to sound a bit up myself - has such high resolution that I may hear things in a way that others do not. But the Terra Firma means that the usual digitalis is so far removed from digital playback, and high frequencies are really affected here (no real surprise) and makes the difference more obvious, IMO.
But whatever, the DC Bias is a DIY option and anybody who has Elsinores may or may not decide to try it.
Cheers.
Joe R.
Old 18th May 2009, 02:47 AM   #526
danieljw's Avatar
thats fine joe,
i am not that easily offended
i will happily admit my system has flaws, probably my room has more flaws than my system any how... the setup to listen to the difference was:
basic sony dvd player (cant remeber model #) nothing special.
optical out into: Denon AVR1905 as preamp:
analogue out into: 50W class A amp based on Hiraga "Le Class A" (linked in my sig line.)
Basically took out the Solen tin foils replaced each with four metal polys and biased with 18V through 100k with 1k in parallel prior to the filter.
to be honest i think to have a fair comparison i would need to use 4 solen tin foils per side, as the normal metal polys are not all that great.
I will probably return the crossover to unbiased with the tin foils
just for neatness.
-Dan
Old 21st May 2009, 12:32 PM   #527
"DC BIAS"
All I can say is, have not wanted to remove it since I put it in almost two months ago.
Joel
Old 4th June 2009, 05:48 AM   #528
rob323 is offline rob323  Australia
What do you do when you only have two half finished speaker projects on the go ..........
Start another one of course
Old 5th June 2009, 10:51 AM   #529
i know these are 8ohm speakers, but what is the efficiency rating for them?
Old 6th June 2009, 04:34 AM   #530
BL4S7ER is offline BL4S7ER  Australia
Rob, would that happen to be a center speaker by any chance?!
Regarding sensitivity of tghe elsinores I have heard 90-91dB being thrown around as a estimate but im sure someone here must have measured them?
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 06:51 AM
A thread to post your "project files" critofur Multi-Way 10 21st March 2008 01:50 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 08:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 05:16 AM
Copyright 1999-2017 diyAudio
