The "Elsinore Project" Thread - Page 51 - diyAudio
Old 6th May 2009, 06:37 PM   #501
Originally posted by critofur
I'm thinking of building a pair of "Elsinores" - except - using these woofers as the upper two:
<snip>
I imagine the crossover change will not be too difficult, cabinet will have to be modified some, should be fun
To really cut costs, I might try these tweeters instead of the HDS:
<snip>
Yes - I know it wouldn't be fair to call them Elsinores anymore at that point - but, who knows, might turn out well?
You are right, Elsinore they would not be, if built this way. But, not to discourage innovation and experimentation you may want to start a new thread for your speaker.
Good luck.
Old 7th May 2009, 02:57 AM   #502
Tyson is offline Tyson  United States
Hello all,
I thought I might post some pictures from my "work in progress" build of the Elsinores.
First, 1 inch (25mm) thick mdf is hard to come by, so I had to buy several sheets of 1/2" (12.5mm) MDF from Home Depot and glue them together.
Lots of Glue:
Lots of Clamps!
Lots of clamps and a great set of tools courtesy of ThomasW (who is an active poster and a moderator over on Hometheatertalk). The tools are great, but Thomas' guidance and expertise was by far the most valuable part of this whole project.
Next day, time to start cutting them to size, courtesy of these saws:
and
and the first pass:
Now, time to start drafting!! This is where Thomas' experience REALLY kicks in, I would have severely screwed this up if I'd been doing it on my own, but with his guidance it was a snap:
Pic of the workspace in Thomas' basement:
Old 7th May 2009, 03:01 AM   #503
Ready for cutouts:
Time to start cutting and routing:
Main Braces are done!
Front panel has bottom sub-panel attached:
Rear View:
Main Front Panel with sub panels attached and routed:
Rear Vew:
Next up, assembly, wiring, and acoustic stuffing. Stay tuned....
Old 7th May 2009, 05:40 AM   #504
BL4S7ER is offline BL4S7ER  Australia
looking good! what finish are you planning?
My elsinores and hamlet? are finished at last!!!! minus the XO. (does that really mean they are finished?)
Will take some pics and post them this weekend.
Old 8th May 2009, 02:18 AM   #505
One more question, I bought a pair of flared ports from parts express, they are 95mm interior diameter. How long should they be cut down to in order to tune the box properly?
The construction drawings indicate the port should be 90mm wide and 80mm long. Since mine is 95mm wide, should I make it 85mm long to compensate?
Old 8th May 2009, 02:30 AM   #506
frugal-phile(tm)
planet10's Avatar
As long as there are no pockets laminated 1/2" will be better than 1". 1/2" MDF & 1/2" Baltic Birch would be even better.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th May 2009, 02:43 AM   #507
since 87mm internal dia = 80mm length
and
90mm ID = 88mm
i would imagine 95mm ID would = ~100-105mm length
Also because they are flared the length begins and ends at the mid point of the flare as per diagram below.
Old 11th May 2009, 04:16 AM   #508
Things are moving along, here's the latest in the build.
Got the braces installed on the rear panels:
And the "stiffening panel" behind the tweeter. Since the tweeter is sealed (not vented), we'll put another board on the back to completely isolate the tweeter from the mid/bass soundwaves.
Sanding out the tweeter leads:
CLAMPS!
Even cooler clamps:
and:
and:
The manly nail gun we used to lock down each side and the mid brace while the glue sets:
Yes, it really is that insane:
ALMOST DONE:
Old 11th May 2009, 04:48 AM   #509
danieljw's Avatar
Send a message via MSN to danieljw
wish i had a nail gun and those clamps when i built mine !!!!
nice work !!!
-Dan
Old 11th May 2009, 05:36 AM   #510
Joe Rasmussen's Avatar
Excellent! Terrific phtos, you obviously also know how to use a camera. What did you use (hinting at my other passion)?
Joe R.
The "Elsinore Project" DIY Speaker System " & DIY "Trans-Amp" - 40 Watt Transconductance Amp
Soon: High Frequency Bias in Tube OPT - "Don't take anything I say as an affirmation but as a question."
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 06:51 AM
A thread to post your "project files" critofur Multi-Way 10 21st March 2008 01:50 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 08:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 05:16 AM
Copyright 1999-2017 diyAudio
