The "Elsinore Project" Thread - Page 5 - diyAudio
Old 7th April 2007, 12:22 AM   #41
whys that?
Old 7th April 2007, 04:01 AM   #42
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Hmm, because of acoustic phase issues and coherense
In a surround setup you are often more than one person (?), and not positioned in the sweet spot
Imagine a standard center speaker with a tweeter and two 6", one on each side - listening off axis means different distance to each 6", not the very best situation
I admit I havent tried it, but generally there are many things in favour of coaxials and with low xo point it ought to work very well as a center - but I havent yet seen any detailed construction
Maybe a good fullrange would work too, but it dont stand severe abuse
Old 7th April 2007, 06:25 AM   #43
but i need it to be timbre matched with the elsinores. i think my only option is the 6.5" Peerless HDS PPB and the Peerless HDS tweeter...
Old 7th April 2007, 07:59 AM   #44
Joe Rasmussen's Avatar
The problem is that either you do the hard yards yourself or find a suitable design. Being a middle channel you'd probably look for a 5" based design. Either a single driver with tweeter in vertical alignment or two drivers laterally with tweeter in the centre. Either way in order to get the symmetry right.
Question - did you use PPB cones or the Nomex, 830874 or 830875?
Material related to Elsinore Mk2 is now posted.
The main page is www.customanalogue.com/e lsinore/elsinore_index.htm and this has a nice picture of a veneered pair in my sound room.
The more technical details/updates are found here: www.customanalogue.com/elsinore/elsinore_mk2.htm
Joe R.
The "Elsinore Project" DIY Speaker System " & DIY "Trans-Amp" - 40 Watt Transconductance Amp
Soon: High Frequency Bias in Tube OPT - "Don't take anything I say as an affirmation but as a question."
Old 7th April 2007, 11:23 AM   #45
Wonder how it would work with a redesigned "Elsinore" as a power center - same drivers and same crossover
Old 7th April 2007, 11:45 AM   #46
Wonder not!
Joe R.
Old 7th April 2007, 03:52 PM   #47
Well, here is what I actually suggested in the first place
http://www.madisound.com/MD04.html
And will probably work fine as rear speakers too
And you can even get cheap cabinets
Old 7th April 2007, 06:48 PM   #48
I used the PPB cone.
i already have a complete system, but nothing matches and it bugs me!
i've got a JBL EC35 center, paradigm mini monitor rears, and Angstrom subwoofer.
i would like everything to be timbre matched, but aren't i obligated to use the PPB cone (whether 5" or 6.5") and the HDS tweeter?
Old 8th April 2007, 03:47 AM   #49
I may be able to help, but we are talking about a single 5" HDS PPB with XT25 tweeter. If used above listening height, the tweeter must be above the 5" and if below, then the tweeter must be below 5". It's a small 7 Litre approx box tuned just under 50Hz with a rear port. The overall voicing is compatible with Elsinores. The crossover techniques are similar etc. Interested?
Joe R.
Old 8th April 2007, 06:13 AM   #50
yeah im interested! we can't use the peerless tweeter instead?
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 05:51 AM
A thread to post your "project files" critofur Multi-Way 10 21st March 2008 12:50 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
Copyright 1999-2017 diyAudio
