The "Elsinore Project" Thread
Old 14th February 2009, 10:46 PM   #381
danieljw is offline danieljw  Australia
danieljw's Avatar
Send a message via MSN to danieljw
Finished Boxes
(Thanks for Rob, Helmuth, Tinitus and Obviously Joe's Advice)
Havent listened to them yet I am still building the crossovers.......
Will be a week or two because of work commitments...........
-Dan
Old 15th February 2009, 01:17 AM   #382
Joe Rasmussen is offline Joe Rasmussen  Australia
Joe Rasmussen's Avatar
Originally posted by danieljw
Finished Boxes
-Dan
WOW! They look really nice. Good work.
You are right about soldering the tweeters, but not unique to just these tweeters.
Joe R.
The "Elsinore Project" DIY Speaker System & DIY "Trans-Amp" - 40 Watt Transconductance Amp
- "Don't take anything I say as an affirmation but as a question." Niels Bohr
Old 15th February 2009, 01:51 AM   #383
David Gatti is offline David Gatti  Australia
David Gatti's Avatar
Originally posted by Joe Rasmussen
Take a look at this post:
http://www.diyaudio.com/forums/showt...06#post1161906
Focus on the Vifa XT25 Tweeter - incredibly flat ON axis (reputably goes up to 40KHz), but how the OFF axis response is dreadful (almost -20dB @ 20KHz).
I used this tweeter in Mark 1 version of the Elsinores with waveguide. The OFF axis response was hugely improved by the waveguide. Others have noted this as well. Indeed I mentioned the Lipinski L707 earlier that also uses XT25 and has been measured with an improved OFF axis response.
The HDS tweeter is a very different kettle of fish. If you haven't read the whole thread, you might find it interesting, starting here:
http://www.diyaudio.com/forums/showt...5&pagenumber=1
Joe R.
Thank you Joe.
Its surprising how the waveguide improved the off axis performance.
Did you find a similar outcome with the Mark 3 (stepped felt) version where I'd assume the felt would absorb some of the off-axis energy?
Old 15th February 2009, 08:01 AM   #384
Originally posted by David Gatti
Its surprising how the waveguide improved the off axis performance. Did you find a similar outcome with the Mark 3 (stepped felt) version where I'd assume the felt would absorb some of the off-axis energy?
Yes and no. The felt being absorbent is not so much the whole point here, it is as much the shape that is important. But felt is good stuff to use and reasonably easy to get results.
The strengthening of the off axis response I believe is due to boundary effects. The way I see it, it will stiffen the air impedance enough to lift the output closer to the boundary (which is in line with the off axis). The off axis output of the tweeter itself is not increased, so it has to be an acoustic Z factor. I would love anybody reading this make any comments - and any explanation they might have. Think of folding the sound forward rather than absorbing it or dissipating wide on a flat baffle. But that 'forward' is still off axis and in fact reinforces it. I am trying to paint a word picture.
At the bottom of the passband, the waveguide has an additional effect. It has a similar result as if increasing the surface area of the tweeter. Again an acoustic Z factor, but a different type. I believe this is desirable as the area of the midrange cone is relatively larger, in fact much larger, than the tweeter at the frequencies where they intersect (crossover), even allowing for the midrange cone decreasing its radiating area as it gets closer to the crossover (it can only do so much as the beaming effect gives it away). It allows for a more gradual acoustic hand-over between the drivers. So the gradual decrease in radiating area is just that, more gradual and less obvious to the ear. Remember, it has to go from wide down to just 1 inch (25mm) into the lower and mid treble.
Waveguides are deceptive things and not immediately obvious the good they can do.
Joe R.
Joe R.
Old 15th February 2009, 05:03 PM   #385
nitronori is offline nitronori  Italy
Hi danieljw, great work! Could you show me a closer pic of the felt around the tweeter? Is it felt?
The moral of my little story is i wanted to let other constructors know that the tweeter terminals need to be soldered quite quickly so as not to damage the coil wiring. so no one else has this mistake
You had a bad experience, but you came out of it good, great work again.
But fortunately I used speakon terminal for all the drivers in this project
2wheels good 4 wheels bad
Old 15th February 2009, 07:02 PM   #386
danieljw's Avatar
Hi sorry i cant take a pic of the felt today (Work)
it is 3mm felt stacked together to make the thickness.
I am going to purchase the correct thickness soon.
-Dan
Old 20th February 2009, 03:13 PM   #387
marchel is offline marchel
Default Good news and bad news
Good news to those who want to build this speaker cause the nomex wofer is on sale at Madisound as of today, the price now is o nly $42-.
The bad news is , The driver might be replaced with a new model.
Old 20th February 2009, 03:55 PM   #388
CCU is offline CCU  Denmark
Send a message via MSN to CCU
Default Re: Good news and bad news
were did you hear that?
Old 20th February 2009, 10:27 PM   #389
Default Re: Re: Good news and bad news
Hi, Nobody told me that, I'm just speculating, I've indicated it in my sentence be saying "might be".
OTOH, Some of the siblings of this drivers in the entire current peerless line are discontinued. Some 4" midbass and the Exclusive 5" , So this could be next.
Old 22nd February 2009, 08:47 PM   #390
jpvt68 is offline jpvt68  Australia
Hi, I've been waiting for a shipment of these drivers to come in and have been told the wait is because they are being made in a new factory
The "Elsinore Project" ThreadHide this!Advertise here!
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 05:51 AM
A thread to post your "project files" critofur Multi-Way 10 21st March 2008 12:50 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
