The "Elsinore Project" Thread
Old 6th February 2009, 09:03 PM   #361
danieljw is offline danieljw  Australia
danieljw's Avatar
Send a message via MSN to danieljw
here is where my build is at.....
PS Rob and Tinitus,
I am using a countersinking bit/drill with 8g x 50mm
cheers for the advice.
Old 7th February 2009, 10:30 PM   #362
MadMutt is offline MadMutt  Australia
Default Re: Re: Great idea. great project name
Originally posted by Joe Rasmussen
Alright, it sounds like Hamlet in 2009 will happen. All interested parties stay posted.
Within a couple of weeks I will post a provisional Hamlet crossover based on what available modeling material I have here.
Joe R.
I am so waiting for these.
Friend wants me to build a small two way.
Any info yet on;
choice of drivers ?
cabinet volume ?
Many thanks for all your hard work and effort....
Old 7th February 2009, 11:41 PM   #363
Joe Rasmussen is offline Joe Rasmussen  Australia
Joe Rasmussen's Avatar
Default Re: Re: Re: Great idea. great project name
Any info yet on;
choice of drivers ?
cabinet volume ?
What is your location? Sydney or nearby?
Joe R.
The "Elsinore Project" DIY Speaker System & DIY "Trans-Amp" - 40 Watt Transconductance Amp
- "Don't take anything I say as an affirmation, but as a question." Niels Bohr
Old 8th February 2009, 09:12 AM   #364
danieljw's Avatar
still waiting for drivers and crossover parts...
little bit of progres today though
Old 8th February 2009, 03:28 PM   #365
imadork is offline imadork  Norway
I'm also eager to follow the progress of the "Hamlet", as I have recently hired a carpenter to build the Elsinore cabinets with a special birch finish (sorry, the norwegian-english dictionary didn't have the translation for "flammebjørk"...)
Having a matching centre channel would be great as I believe my current PSB C60 will be a gross mismatch with the Elsinores (and I need a solid stand for my 52" Samsung ). If there is a 99% likelihood that the current cabinet drawings from page 4 will work fine, I'm all set to go. Guess the X-over design might change before the Hamlet project is finalized, but I'll follow the progress here closely. Keep up the good work, fellas..!!
Old 9th February 2009, 07:18 AM   #366
Joe R.
Sorry, no where near you.
Brisbane.
I've met Rob, but sadly had to go (audio meet) before I heard his Elsinores.
They look brilliant though....
Old 9th February 2009, 02:35 PM   #367
mantraxl is offline mantraxl  United States
I am confused, will the Hamlet center channel speaker be a horizontal MTM, or a BMTMB? Since both have been under discussion recently, I am unsure. I personally am hoping for the bmtmb, since A) I would like to have a large and dynamic center to match the Elsinores that I am starting to build, and B) because I think that I could learn a lot at how the crossover is changed to accomodate the same drivers in a different orientation.
An idea I had was that one could make a square center channel with a vertically arrayed MTM, and then place the bass-reinforcing midwoofers to the sides of the tweeter. A diamond shaped arrangement on a squarish (or wider) baffle. The idea is that you still have a somewhat compact speaker, but minimal comb filtering, since hopefully the bass speakers would be close enough to one another as to not nullify one another significantly. Does that make any sense?
Looking forward to the latest developments!!
Old 9th February 2009, 10:14 PM   #368
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Your project looks great Daniel , I want to use the peerles HDS tweeter in the future because it must be very good sounding.
Go on with the good work
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 10th February 2009, 06:07 AM   #369
Definitely MTM as seen post 60:
http://www.diyaudio.com/forums/showt...01#post1184401
This would be suitable for centre channel and rear channels, indeed all round it preferred. That means that Elsinore and Hamlet speakers can be used flexibly in multi-channel and AV situs.
Other than that, there is nothing proposed. Not until at least the Hamlet is done.
Joe R.
Old 10th February 2009, 07:45 PM   #370
nitronori is offline nitronori  Italy
Some pics of my Elsinore Do you like them?
From left to right on the table AMC 2030 amp, in the center Vincent preamp, Nad CDP Onkyo CDP, on the left Hafler amp over DB Technologies MT530 amp.
This is the external crossover box. I want to cover it with plexiglass.
I wanted to use more highend component, but in the end the cheap side of me prevailed. I'll try in the future a better tweeter resistor than MOX I used; however MOX resistor are normally used in "highend" kit published in hifi magazines, so they must be not so bad.
I have calm my room, I read your article Joe that features triangles and strips, yes for sure they're effective but they aren't the nicest thing in the world to furnish the room, unless they have the name of a famous designer on it
A large bookshelf behind the speakers and heavy drapery could do the job?
In the last post I forgot to mention:
The sound coming out the Elsinores has also a great "vertical dimension" wich add a lot to the perception of the soundstage.
2wheels good 4 wheels bad
The "Elsinore Project" ThreadHide this!Advertise here!
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 05:51 AM
A thread to post your "project files" critofur Multi-Way 10 21st March 2008 12:50 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
