The "Elsinore Project" Thread
Old 22nd January 2009, 05:06 PM   #331
Joel Wesseling is offline Joel Wesseling  Canada
i chose the 3mm plywood because its bendable, i'm going 2 make both sides and back in one piece of ply (kinda like B&W's 800D) and the same shape as the B&W 804S
Consider leaving the cabinets the way there designed. Joe has went to great lenghts to have amazing sound come out of simple to make cabinets..
When I arrived at the point where all the panels where dry fitted I thought they looked very, very nice and much better than any picture has show..
The trick to a beatuful look then lies in how the finish is done using one or a few of the many materials available..
When your listening to the Elsinore cosmetics become
unimportant..
Danger: If you assemble and listen before you put the finish on, like I did, it will be very hard to shut them down to complete the surfaces...
Joel
Old 22nd January 2009, 08:31 PM   #332
CCU is offline CCU  Denmark
Send a message via MSN to CCU
unimportant..
Joel
well the cosmetics is mostly a GAF problem and GAF is a huge problem if it isn't there!
plus i like the challenge and i WILL be comparing the 2 speaker kabinets, hopefully my version will be as good as the original.
BTW i've ordered some crossover components
clarity cap SA series for all caps exept 68uf which is a Jantzen crosscap
Coils: Jantzen baked air coils. But haven't been able to find a 9mh coil, except for a 1.2mm air coil which seems insufficient for bass(in my mind) need to find something sutible
Risistors: duelund througout the crossover
based my choice of caps partly because of this test
link
Old 25th January 2009, 04:20 PM   #333
DanielG is offline DanielG  Australia
I'm seriously interested in buying the kit from Joe, but I was wondering if there's anyone in Melbourne (AUS!) that has a pair that I could come around and listen to first?
And another question while I'm at it: Can anyone recommend a reliable shop that could cut (and possibly build?) the cabinets for me? I have virtually no proper tools, and I don't want to screw it up if I end up building them.
Old 25th January 2009, 05:26 PM   #334
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I would also like to know that...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th January 2009, 05:36 PM   #335
Joel
I'll remember that
Old 29th January 2009, 12:03 AM   #336
danieljw is offline danieljw  Australia
danieljw's Avatar
Send a message via MSN to danieljw
Hi all,
I have decided to take the plunge and build a pair of Elsinores after talking to Joe acouple of weeks ago. and reading ALL the info on joes site.
I have a question for people who have built the speakers,
when you countersink the screws in the MDF can you tell me the specific countersinking tool and brand you used ?
and the screw and pilot bit sizes you have used ?
the reason i ask is previously i have seen MDF warp or bow at the screw joint and i want to avoid this for a nice smooth finish.
-Dan
Old 29th January 2009, 12:51 AM   #337
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally posted by danieljw
Hi all,
-Dan
Hi Dan
Today I dont use the normal countersinking, I have used it a lot in past though
I have found a much better way
You need a wood drill with center tap
Its a standard drill fore wood
Size is what fits the head diameter of your screws, preferably not too big...thin screws are best fore MDF, less risk of splitting
Just drill deep enough so that the screwhead is just below surface...about 1.5mm
This way you get a hole as small and smooth as possible
Further putty will be much easier and better lasting
If you want it real nice, and have some skills, you take out the screws once the glue is dried
Then drill the holes deeper using same drill, could be all the way through both items
Then plug the holes with woodplugs and glue
Fore finish I use a small handsaw with fine tooths, and at last a sharp chisel...but I suppose it could be done by sanding also
These days, to get rit of the putting, many prefer to do without screws and use glue only
In case of that I suggest to use a couple of small countersinking nails, to fix the plates while tightening the clamps
Man, I really needed my dictionary fore that one
good luck
sometimes we know very little, and sometimes we know too much
Old 29th January 2009, 12:58 AM   #338
danieljw's Avatar
Thanks tinitus,
i appreciate the info,
I take it you mean a "spade bit" in the same diameter as the screw
= new idea i might try
thanks
-dan
Old 29th January 2009, 01:08 AM   #339
Well, like you say...a picture says more than words
You may also look at page "i2" in this document
http://www.wolfcraft.de/workarea/sup...s/BAL/3750.pdf
Old 29th January 2009, 01:20 AM   #340
danieljw's Avatar
Thanks tinitus !!!!
The "Elsinore Project" ThreadHide this!Advertise here!
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 06:51 AM
A thread to post your "project files" critofur Multi-Way 10 21st March 2008 01:50 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 08:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 05:16 AM
