The "Elsinore Project" Thread
Old 21st May 2013, 11:02 AM   #1551
ABO is offline ABO  Netherlands
Hello Guys,
I ordered Joel's waveguids ages ago but never got around to actually building the speakers. I've gone through the build thread with renewed interest and, with respect to the waveguide, I conclude that I should mount the tweeters to the waveguides before mounting the waveguides to the cabinets. There is a photo by JkdJake where a gasket is shown to seal the tweeter faceplate to the back of the waveguide. I believe that is good practice in any case.
Apparently there is also is a small gap, between the tweeter and waveguide, around the dome of the tweeter. If I understand correctly, this was not an audio design objective, but an intentional tolerance to make sure that the tweeter will always fit securely. There has been some debate whether this gap should be sealed or not.
I wonder if there is consensus now on this issue?
Old 21st May 2013, 09:38 PM   #1552
Joel Wesseling is offline Joel Wesseling  Canada
Originally Posted by ashaw View Post
I am interested in getting a set of waveguides for the Elsinore. Is there any chance of that anymore?
I can have more made..The machinist has raised his price so I would need $180 per pair.. I have to get min 5 pairs at a time and would need money in advance as I cant justify holding stock because I'm adding very little for time and fuel... If 5 people are interested, no problem...
ABO, as for the gap you should just try it both ways and then you will know which one is for you.. Each way is different good.. One way is gap without putty and the other is tight with putty.. I'm guessing that some energy at the large diameter of the dome is getting trapped in the gap so there is a loss of richness and detail but its smoother and more laid back than the tight fit... Take your pick but I chose no gap..
Old 21st May 2013, 11:49 PM   #1553
kingfisher is offline kingfisher  Canada
Default wave guide
Hey Joel, I will order a pr. pm my name for details on where to and how to get $ to you.
kingfisher
This will make 2 orders!
Old 31st May 2013, 07:30 PM   #1554
tpate is offline tpate  United States
I built my own wave guides out of mdf,that I like the sound of a little better than the metal. I have a pair of Joel's aluminum wave guides I am not using, I will sell for $150 US plus shipping. I don't know how much international shipping would be. Not trying to get in your business Joel but I would like to see someone get some use out of them.
Old 2nd June 2013, 10:28 AM   #1555
irext is offline irext  Australia
irext's Avatar
Out of pure curiosity. Why did you prefer the sound of the MDF waveguides? What difference did you notice? I built my Elsinore's in 2011 using Joe's MDF waveguides but if I was building them now I would probably use Joel's round alloy ones (if obtainable) as I think they are aesthetically more pleasing but I've often wondered if there would be an audible and or measurable difference between them and Joe's MDF ones. I have observed that a machined piece of alloy rings somewhat when struck whereas a piece of MDF is quite dead. Food for thought.
Old 2nd June 2013, 12:26 PM   #1556
petefrontiers is offline petefrontiers  Canada
I have an extra set of high quality coils and capacitors from Erse Audio to sell. These are the same parts I used to build the filters of my Elsinores. This is an almost complete kit, only the resistors and C1 capacitors are not included. All parts are new and never been soldered. I paid over $300 for these parts and I'm selling them $200. pm me for details if you are interested
Old 2nd June 2013, 04:08 PM   #1557
I found that the mdf wave guides were not quite as bright or edgy as the aluminum guides. I was also able to control the gap better with the mdf. In my system the gap made the presentation much more 3d with nuances that I didn't hear with the gap closed. Also, I could listen to the speakers for hours without any fatigue. At first listen the closed gap sound jumps out at you more and is more "impressive".
Old 3rd June 2013, 07:36 AM   #1558
irext's Avatar
That's very interesting as I find mine a very easy unfatiguing listen. Others have agreed (love showing them off). The gap between the tweeter and the waveguide is as per the original design dictated by mounting the tweeter facia flush with 25mm baffle and the MDF waveguide flush with the two 18mm front baffle pieces which does introduce a small gap. A collegue of mine has access to a 3D printer and if possible I would love to print a waveguide and compare.However I will have to model it first in a CAD program (SolidWorks). Learning that will be the hard part.
Old 11th June 2013, 12:03 AM   #1559
No Problem with me if you can sell them..
Old 11th June 2013, 12:31 AM   #1560
Joe Rasmussen is offline Joe Rasmussen  Australia
Joe Rasmussen's Avatar
They are a PAIN...
We made some and no more !!!
Cheers, Joe
The "Elsinore Project" DIY Speaker System & DIY "Trans-Amp" - 40 Watt Transconductance Amp
- "Don't take anything I say as an affirmation, but as a question." Niels Bohr
The "Elsinore Project" ThreadHide this!Advertise here!
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 05:51 AM
A thread to post your "project files" critofur Multi-Way 10 21st March 2008 12:50 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
