The "Elsinore Project" Thread
Old 17th February 2013, 01:20 AM   #1491
sibbeli is offline sibbeli  Sweden
SHARKY and I are the one who works together in the project of building a form so that we can build WGs in carbonfibre and epoxy.
SHARKY is the one that takes the part of getting a good mould finished, after that I take over and make them in carbonfibre/epoxy.
We in Sweden wants them in carbonfibre, but it is also possible to make them in glassfibre/epoxy/polyester.
SHARKY and MY goal is to make the available for all other persons that might have interest in a pair.
The price will be reasonable, the price shall cover the materials cost and for my work i will take a real low ammount. I think i have to lay 3 hours minimum for a pair of carbonfibre WGs.
In that stage, the reciever have to laqcuer it himself to get rid of the tiny tiny holes that always appear, i needs to be laquered maybe 3 times before you have clear carbonfibre WaveGiude with that so sexy sweet fibre look!
I can ofcourse laquer and wetslip them self, because they need to get wetslipt between every layer of clear laque but that is a tedious job i reallly dont like but i can do it for payment.
Joels ALU WG costs 160CAN +shipping and a sutable price for these in carbonfibre would be a bit lower than that. BUT, these will weigh maybe 4/500 grams so the shipping cost would be significantly lower.
Carbonfibre is an expensive material and Epoxy isnt especially cheap either.
We want to make them available for all of you out in europa that cant order from Joel just because the shipping for two heavy ALU WGs to europe is totally insane..
I hope someone feels like we are doing a good job making WG available to all??
Old 22nd February 2013, 09:53 PM   #1492
Sharkythefrog is offline Sharkythefrog  Sweden
Originally Posted by jdkJake View Post
irext,
Here is a link to Joe's poly material. It is R3.0 in density:
Hope this helps.
Have large problems with damping material here in Europe. Nothing close to what you guys have mentioned in sight here. To continue looking what is the value R3.0 stand for? What we have seen here is things like xxKg/cbm (kilos per cubik mete.
Old 22nd February 2013, 10:14 PM   #1493
Joe Rasmussen is offline Joe Rasmussen  Australia
Joe Rasmussen's Avatar
Just want to add, that a large part of the space behind the brace and above the port, needs to be near 'filled' - not completely, but mostly like 80% is nice. And not heavy or too dense material.
The area in front of the brace is 'lined' - so you can see that part of the box is largely 'filled' and partly 'lined' - this gives the alignment a certain resistive property (and makes the box looks larger to the drivers).
In theory, if with the correct port dimension, if the Fb ends up higher than 35Hz, then chances are you do bot have enough fill behind the brace. It is not super critical, but if you can test for the Fb frequency of the completed box and you don't get Fb 33-35 Hertz, then increasing rear fill and/or increasing port length, this kind of tuning can be done.
If anybody wants to test their FB, let me know - and maybe I can make appropriate comment.
Cheers, Joe
The "Elsinore Project" DIY Speaker System & DIY "Trans-Amp" - 40 Watt Transconductance Amp
- "Don't take anything I say as an affirmation but as a question." Niels Bohr
Old 22nd February 2013, 10:53 PM   #1494
Cheers, Joe
Thanks Joe,
Yes I have had the design drawings printed in front of my eyes many times trying to figure out what to use.
What we have here is just the ordinary polyester fill which is not at all that good in either damping resonance or enlarge the box. I do have quite an amount of loose speaker damping wool in my basement somewhere since many years but it will not stay in place losely stuffed in the back compartment of the box.
The two most known high end speaker factories here in sweden actually (after contact with them) use the simple "standard fill" glass wool batts as used by many DIYrs me included earlier). But I think I remember someone in the thread having some comments about this material in conjuction with the elsinores.
If finding some loose glasswool that might be an option. just 15-20 mm on the front compartment walls and maybe my wool stuffed between the 50mm back braces covered by someting like 50mm glass wool. If i can find light enough glasswool.
Old 22nd February 2013, 11:00 PM   #1495
Default R-value?
Still trying to find out what the R-value stands for. The producers of the damping materials in this thread doesn´t explain either on their homepages... Would be good to understand to be able to have a discussion with producers here in EU.
Old 22nd February 2013, 11:56 PM   #1496
It is an Australian Standard. Take a look here:
LINK: R-value - what is it? - Home Insulation Buying Guide - Home Insulation Scheme Review - CHOICE
Generally, the higher the R value, the more like thick the batt will be.
R3.0 is mostly about 165mm approx - this is near perhaps a little high and R2.5 is OK too.
As I said, behind the brace it is largely filled, but don't use anything high in density, and the area above the port. The front of the brace near the drivers are lined.
Typically a vented/reflex box is only lined and sealed boxes are filled. But using some level of fill in a vented box, carefully positioned so that air-flow between the rear of the driver to the port is not restricted, you can get quite a boost of Vb - so that 70 Litres looks a lot closer to 100 Litres. This means the port dimension are affected in such a way that "port calculators" don't work - the port will be shorter by quite an amount for the same Fb.
If you have a sinewave generator (you can often use a computer) and measure Fb using a simple 10 Ohm series resistor and an AC multimeter - it is not hard to do. Aim for fill and port length to get you a 33-35 Hertz target.
Cheers, Joe
Old 23rd February 2013, 10:51 AM   #1497
Cheers, Joe
Great link.. It explains it all as there where a matrix with different materials, including glass fibre batts. Makes it easier to start measuring.
Br
//H
Old 23rd February 2013, 10:29 PM   #1498
prairieboy is offline prairieboy  Canada
prairieboy's Avatar
Interesting ... Australian R values are significantly different than North American. Aussie R3.5 (140 mm of medium density fibreglass) is equivalent to what 'we' (North Americans) call R20, which is the standard batt shoved into a 2 x 6 stud space (2 x 6 is actually 1.5" by 5.5")
Old 23rd February 2013, 11:40 PM   #1499
Cheers, Joe
Never measured this before, but now i will. Computer output with sinus wawe to amplifier and to speaker. Measuring the resistance (of the whole speaker or just over the base elements?) over + and - poles vith the multimeter in series with a 10ohm resistor (why?) or how do you mean?
When the resistans increase to its top i have the speaker resonance Hz????
Old 24th February 2013, 04:08 AM   #1500
Make sure you have no crossover attached. Just drive the four driver together by connecting jumper. Use a 1.5V battery and make sure they all move out together (or in together, depending on which way the battery is turned around). That makes sure they are all in the same phase. Now apply the signal. Using the series resistor, it is most common to have the AC meter across the speaker terminals. Below 100 Hertz you should have two peaks and a saddle in between. The higher peak may be around 70 Hertz and the lower peaks in the 20s of Hertz. The saddle, where the meter reads lowest, will be the Fb of the box and around 33-35 hertz.
Cheers, Joe
The "Elsinore Project" ThreadHide this!Advertise here!
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 05:51 AM
A thread to post your "project files" critofur Multi-Way 10 21st March 2008 12:50 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
