The "Elsinore Project" Thread - Page 144 - diyAudio
Old 19th January 2013, 01:23 PM   #1431
Originally Posted by sibbeli View Post
Well, i think i will have a go at crating a waveguide.
When they were done in mdf, how did you do it then? CNC?
I have access to a drill lathe, and i have access to different plastics.
I have access to a full carpenter shop without a horisontal lathe. Donīt know that word but that machine you use to carve out legs to chairs and such. That machine, no access.
I can do a model in clay and then make a mold out of it and then do it in glass/carbon fibre. That does seem like a lot of work thou.
Feels like i am missing some obvius way to make it..
Right now I have only 5 waveguides with 4mm mounting thickness..The machining cost more.. They're were made for My own ideas and use with a more rigid(steel) front panel where the waveguide wont be sunk and have plan for rigid panel in a Hamlet centre as well..
The cheapest shipping to sweden $25 but it doesn't come with insurance so I kind of stayed away before. So without duty it's 200 total. With the regular 18mm guide its $185 but need to get more..
May I please give more thoughts and challenges..
If you build m4 you will likely be very happy without knowing the difference but I have hundreds of dollars worth of parts laying around from past version that might never find a new home..
I'm waiting for a great 300B thats being made but have a few others here now like el84 and 6mb8 integrates.. The 6mb8 has a msrp of 899 and it's small with smaller transformers and no choke in the power supply. 6mb8 is a 6w integrated all in one tube and this amp sound really good on the Elsinore and control is very good..
m4 dosent have this ability from memory and I think a larger 8w amp would be minimal and still a bit of overhang bass unless using a bit higher power.. Then I ran 100w accuphase a lot for maximum firmness..
The improvements MK5 are HUGE and improvements are across the board..
It still amazes me that when I hear some $80k speakers I find there is something out of whack with balance and integration..
What about taking the time and putting money into machined aluminum front panel or at least the stiffest material you can come up with beyond wood.. you can use my waveguide or better yet have waveguide machined into the front panel..
Whithout the stiffness the speakers are already great and it simply increased the detail and focus but why not and it could look cool..
I guess for me Hot Rodding Elsinore Mk5 makes the most sense..
Old 20th January 2013, 12:13 AM   #1432
Joe Rasmussen's Avatar
I do approve of mounting the Tweeter directly to a large mass. If you note the cabinet design, where the Tweeter is mounted is designed to be as strong as possible and as "massy" as possible. In fact, it should be the strongest part of the box. It increases focus where the wavelengths are shortest.
So how much mass does acrylic have compared to the inequivalent of aluminium? If acrylic, it is still pretty good I would think.
From an acoustic point of view, it is the shape of the Waveguide that is important, but mass is about stability. The Waveguide we came up with, if we were to change its shape, we would have to re-start the computer modelling from scratch. And it would likely work OK with a new shape - but the Crossover would have to be changed too.
I don't think I have mentioned this earlier, but the target of the design of the Waveguide was based on getting maximum "gain" at 3KHz, the targeted Crossover point, so that the smallest value series cap could be used - to make the reactance in the cap - which increases as you lower the value, keep it as high as possible. The reason is that high reactance between the amplifier's output terminals and the Tweter's VC terminals, means that the Tweeter will track the current of the amplifier, rather than the voltage. The Tweeter responds more linearly to current than it does to tracking voltage, and also generates less noise due to EMF forces (which are voltages) corrupting the current. The only other person I know who seems to take this seriously is Esa Merelainen in Finland. It just seems to go over the heads of the masses of loudspeaker designers.
Cheers, Joe R.
The "Elsinore Project" DIY Speaker System " & DIY "Trans-Amp" - 40 Watt Transconductance Amp
Soon: High Frequency Bias in Tube OPT - "Don't take anything I say as an affirmation but as a question."
Old 20th January 2013, 05:41 PM   #1433
I will start my project during this spring and have already realized that the nice waveguides from Joel will be to expensive to transport to Sweden. Therefore I have somewhere in my head about the same thought that You have. Lets make a mould and then use some plastic to cast them instead. what are your timeschedule?
Old 20th January 2013, 05:50 PM   #1434
Hi again!
There is no need to worry if it isnīt possible to upgrade to Mk 5 in the same box or that it uses a new crossover. My plan has almost the whole time been to build a cheaper box, with a little bit chaper xo parts as a beginning, and then later on build a REAL fine version when the funds allow it. With no cheapish parts, no budget thinking what so ever.
This is possible, right?
The difference in price for Mk3 and Mk5 crossover parts woul be almost none as there are not that many parts that need to be top noch. So therefore itīs just the waveguide that is the big difference. So letīs get a Pan-european" waveguide project enabling your Mk5s come to life from the beginning
Old 20th January 2013, 09:14 PM   #1435
sibbeli is offline sibbeli  Sweden
That sounds like a good idea!
I am about to ask some friends/family of mine with experience in doing models, My father, He has been working with making models for 25 years at the now only existing swedish car company. So he knows how to make it, he is just quite bizzy.
I am also about to ask another close relative that is a guitar/furniture carpenter about his ideas of making a waveguide. He is also really good at these things.
If i just get at good model done, then i will have no problem making them from carbon/glass/kevlar fibre and suitable epoxi/polyester/whatever plastics.
Its the mold thats the hard thing to get done right. My father know how to do this.
But, i am going to push this a bit and see what i get for suitable ideas.
Do you have any ideas?
A clay modell is what me thinks so far, or maybe making one out of wood and then make a negative out of it.
About the crossover, i only checked the price for the mk5 xo, and it wasnīt expensive at all. Some 300 sek per speaker i think. Then it was as specified but without the Rifa cap as i didn't find any of those.
Where do you buy xo parts from?
Old 21st January 2013, 05:38 PM   #1436
Good news. I have access to a lathe.
So, now its time to figure out a good design and make it. Then make a negative and try to make a waveguide out of some plastics.
I think maybe i should try carbonfibre out at first.
What do you guys think?
I have carbon fibre, a small amount of kevlar and lots of glassfibre available.
Epoxy and poyester do i also have. I think glassfibre is going to be too flexy and wobbly.
Carbonfibre is stiff, really stiff when done the right way, and i think it would be a good idea to use some dampening, maybe a thin sheet if bitumen moulded into it? Donīt know, just guessing.
I need your help figuring out what i should try first.
If you have the ability to do this, what would you have tried first?
If i i get a good mould done that i can stand for, then i can make some more for material cost and some labour cost.
If that is okey for you Joe? Nothing set, just exploring the options.
Could be a good idea to have the waveguides available in europe?
They wouldnīt be too heavy either so shipping shouldnīt be too much.
How do you think it should look like? I like the round shape. Fits with the drivers. Could make it the same shape as the 830875 drivers? How thick flange? 5mm should be sufficient i think. 10mm is possible too but then the weight and cost will rise. No probem when done for just me as the material is free for me, already paid for.
Lots of ideas to try out, fun
sharkythefrog, can you pm me swith your email?
I am about to order drivers from the netherlands, all drivers incl shipping is 4,700 sek. If we do it together i am almost certain it would be cheaper, they give discount for 10 drivers so they probably give discount for 20 too.
Just a idea. But i am going to order them very soon as i need a tweet flange to make a mould done.
Old 23rd January 2013, 09:19 PM   #1437
dondiba is offline dondiba  France
hi, this project seems very interesting
is there a link to :
-a list of the parts for the last version
- and are they dealers in europe?
-and what is the estimation of the cost ?
thank you
dondiba
Old 24th January 2013, 10:29 AM   #1438
pguerin is offline pguerin  France
Bonjour,
You can find all the parts in Europe from internet boutique except the wave guide
Concerning the cost I think around 1200 € with the box and all the crossover parts, damping etc.
Old 24th January 2013, 09:08 PM   #1439
Pascual, Dondiba,
We are a few i Sweden that will try to put together some Elsinores. Approx costs: Elements €520, filters €100, damping - not found yet, cabinett - could be whatever - but raw cabinets €100. We also try to bring a European version of the waveguide to life as the cross atlantic hipping cost is not at all fun. Pascual - where did you find the correct damping?
Old 25th January 2013, 07:52 AM   #1440
Hi everybody,
I've haven't build the Elsinore yet but the Nomex 164, you can have a look at my blog, there is a section concerning the costs.
Construction d'enceintes "Nomex 164" - Le blog de pguerin
I think building the Elsinore under 1000 € would not be easy, I mean including ALL parts.
About the waveguide, I already own a pair from joels.
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 06:51 AM
A thread to post your "project files" critofur Multi-Way 10 21st March 2008 01:50 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 08:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 05:16 AM
Copyright Đ1999-2017 diyAudio
