#1391 | |
I would choose a Hamlet center over a Mini center to go with the Elsinore.. Mostly because the tweeters sound quite different.. I dont have a SS processor and havent heard the mini as a center so cant say how well it might work out.. I have a spot for a hamlet and mostly look forward to seperating dialogue for movies.. I think the Minis should be used as small monitors for Music only.. Hope this helps... |
#1392 | |
I just need to find the time to do the Hamlets - there has been so many things happening. I have the HDS Nomex drivers, need to get another set of HDS Tweeters - at least then have the bits. Cheers, Joe R.
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" |
#1393 |
My Elsinores are about 2 metres apart and I sit a bit over 2 metres from them. All dictated by the room they live in. The biggest difference I noticed was from toeing them out somewhat. This made them less toppy for want of a better word but did not detract from the hollographic sound stage they produce. I've probably said it before on this forum but they are deceptively loud. You think they are just ticking over until someone (usually my wife) tries to talk over them and you can see their mouth moving but that's all. They still blow me away even after having them for 15 months now.
#1394 | |
I'll send a set of tweeters or pay and someone sends local, whichever works best belatedAnyone want to help with other parts along the way? Darn, I have to listen to the Eslinores in stereo until center develops ![]() Joel |
#1395 | |
Some toe-in also made a big diference. Have started with the basic crossover, 1mm tweeter spacer and gap unfilled , 33 ohm resistors across the midrange terminals. They reflect the input quality to a much higher degree than my old speakers. My best recordings now really stand out. |
#1396 |
I understand that MTM for center lying flat has unique crossover?
So a pair of MTM monitors is different than same MTM speaker for center? Is this wrong? Cheers, Joel |
#1397 | |
Let me know what you think we might need.
-- jk -- |
#1398 | |
I generally sit about 9 and a half feet back for the near-field. The Elsinore's are toed-in only a few degrees. The toe-in really makes the difference in the sweet spot location for left-to-right. You will know when you get it set right as it really clicks in when you get it right for your room. I have also noticed the front-to-back sweet spot is much bigger than most speakers. I can sit anywhere from about 7 to 11 feet and get an impressive sound abet with a slightly different set of trade-offs.
-- jk -- |
#1399 | |
We would certainly want to have the option of both building pairs and singles without complications. Cheers, Joe R.
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" Last edited by Joe Rasmussen; 4th January 2013 at 11:53 PM. |
#1400 |
I have a question, one that may or may not arise, re the Hamlet.
When all the measurements are done in-box, both acoustic and electrical, then the crossover can be modelled. At this point we must decide, do we want this to be a 4 Ohm system? Keep in mind that the Elsinores are nominally 8 Ohm (the Z does not drop 5.6 Ohm and qualifies as such), but is in fact a flat 6 Ohm. So a nominal 4 Ohm will actually turn out a 3 Ohm flat Z (it qualifies as 4 Ohm if it does not drop below 2.8 Ohm). Will that be acceptable? A 3 Ohm speaker? But still nominally 4 Ohm. This is with the HDS Nomex drivers in parallel. We can also put them in series as we do with the Elsinores, but here we don't have the bottom two drivers to fill in the diffraction loss and boost lower part of the midrange. Advantage to the Elsinores, the Hamlets are not going to be as easy to drive - but of course that does not mean we are aiming for anything other than a benevolent load. We could end up with a 12 Ohm flat Z system. In both instances the efficiency will be the same (again we are not being exact but simply guided by basic numbers), but the voltage sensitivity will be different. You may ask how that can be? The efficiency is related to how much electrical energy is needed to get to, say, 92dBSPL - so it is current times voltage. But sensitivity is related to voltage alone. So 12 Ohm will need twice (6dB more) voltage swing, but half the current. So to get to the same 92dBSPL it will use the same electrical energy. So 4 Ohm speakers are a lot more sensitive (to voltage) than 8 Ohm. So whenever you look at speakers specs and see the "Sensitivity" - then look at the Impedance too. Back to the Hamlets, the good thing is this: I can model both possibilities, present them here, look at the pro and cons, and only then make a decision - and no crossover made until then. The modelling is actually quite accurate when it comes to this kind of scenario. But the numbers may work out to suit only one choice. So that is the plan, at least now. Cheers, Joe R.
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" Last edited by Joe Rasmussen; 5th January 2013 at 12:34 AM. |
| "Proac 2.5 clone" or "Elsinore project" | Joel Wesseling | Multi-Way | 10 | 26th May 2011 05:51 AM |
| A thread to post your "project files" | critofur | Multi-Way | 10 | 21st March 2008 12:50 PM |
| "compact loudspeaker factory visit from "magico mini" thread | Nanook | Multi-Way | 2 | 4th January 2008 07:30 AM |
| The "Really simple and cheap speaker designs for the newbie!" thread. | Spasticteapot | Multi-Way | 5 | 19th March 2006 04:16 AM |
