#1301 |
Did I post that...? Must have been some time ago.
The two links worked for me. Cheers, Joe R.
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" |
#1302 |
They look brilliant. A collegue of mine is also in the process of building a pair of Elsinore,s and he was also looking at finishing in piano black. I will steer him in your direction if you don,t mind. Very nice work. It,s great to see so many different takes on finishing.
#1303 |
Looks stunning when it's done well and horrible if it isn't.
I think you have to be some kind of Sado-Masochist. LOL Good luck - in the best sense of the word. I wish mine were like that too. Cheers, Joe R.
#1304 | |
Thanks for the complements. And yep you need a spray booth at least and a down draft oven is best. I tried in my shed with plastic everywhere, wet down the floor and used two pack with a very quick drying time and you still get dust particles. Its not bad but nothing compared to doing it properly using the right equipment. A controlled environment is key. Lots of sanding between coats 400 grade up to 1200+ then polishing with a cutting compound. Cheers |
#1305 | |
So it ala CSI - always wear gloves. Cheers, Joe R.
#1306 |
I have 4 JR Mini boxes made up from my cabinet construction experiments and decided I want to complete them.. My question is can I use the Nomex HDS woofer without Crossover change? Thanks, Joel |
#1307 | |
Cheers, Joe R.
#1308 | |
Might be missing what you asking but the crossover I have is same as in post 1306.. Thanks.. Came across a guy in California that had several boxes of the NOMEX Have to search for him again... Joel |
#1309 | |
Didn't see that. Will look at it and report back asap.
#1310 |
| "Proac 2.5 clone" or "Elsinore project" | Joel Wesseling | Multi-Way | 10 | 26th May 2011 05:51 AM |
| A thread to post your "project files" | critofur | Multi-Way | 10 | 21st March 2008 12:50 PM |
| "compact loudspeaker factory visit from "magico mini" thread | Nanook | Multi-Way | 2 | 4th January 2008 07:30 AM |
| The "Really simple and cheap speaker designs for the newbie!" thread. | Spasticteapot | Multi-Way | 5 | 19th March 2006 04:16 AM |
| Page generated in 0.14181 seconds (100.00% PHP - 0% MySQL) with 10 queries |
