The "Elsinore Project" Thread
Old 17th July 2012, 02:46 AM   #1231
jdkJake is offline jdkJake  United States
Interesting.
What is the composition of the material your are now using? Is there an R value associated with it?
-- jk --
Old 18th July 2012, 03:09 AM   #1232
irext is offline irext  Australia
irext's Avatar
The details of the damping material were given as 350GSM Acrylic sound damping material. I bought four rolls of 1.5m x 1m at about 10mm thick ($5.00 per roll + delivery). I had to layer it to get the required thickness. A few dobs of PVA glue here and there to keep it together. I purchased it from an Ebay supplier in Aus. I'm still going to do some more research into procuring the exact material as used by Joe Ras but for now I'm quite happy with the improvement.
Old 18th July 2012, 09:13 AM   #1233
ermat1234 is offline ermat1234  Australia
Let me know Irext if you do track down Joes original spec material as i will take some too.
Old 19th July 2012, 01:07 AM   #1234
I was just curious. As long as the density is low, I am sure you will be fine. Glad to hear it is working out for you though.
-- jk --
Old 1st August 2012, 09:57 AM   #1235
Default neutric
can anyone confirm the hole diameter for the Neutrik fitting.
I dont have the fittings yet but i'm ready to drill. Thanks.
Old 1st August 2012, 11:11 AM   #1236
spoonted is offline spoonted  Australia
Hows this NL8MPR - Neutrik
30mm hole saw/spade bit, you want to get a nice snug fit as there is not much room for the screws.
Old 2nd August 2012, 03:51 AM   #1237
Hi i,ll eloborate on my last post,if using the NL8MPR the drawings call for a 31mm hole but as i only had 30mm holesaw this is what i used along with a small amount of filing to enlarge the hole so the plug would fit nicely.
But if you can get a 31mm holesaw go for it.
Cheers
Old 4th August 2012, 12:07 AM   #1238
Default Port
I must be blind, but i cant find any reference about what port to buy in Australia. Also WES appears to not do a 90mm port. ?
Old 4th August 2012, 04:17 AM   #1239
90mm outside diameter x 80mm long plastic pipe from you local hardware bunnings etc . I think it was stormwater pipe.
Old 4th August 2012, 04:35 AM   #1240
so just an interference fit. 1 hole. 1 pipe. no flange or screws etc. ?
The "Elsinore Project" ThreadHide this!Advertise here!
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 05:51 AM
A thread to post your "project files" critofur Multi-Way 10 21st March 2008 12:50 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
