#1201 |
The gap is in the 2 to 3 mm range. When using Joel's wave guides I hot glued some coins, dimes to nickles, for spaces to the back of the guide and put some thin foam an inch or so around the hole to make a seal. You can adjust the effect by how thick the coin is and how big of a ring of foam you use. I ended up using the home made guides I started with as the mdf seems to impart a little less edge to the sound. The Bolser mod makes it where you can toe in the speakers more like you are used to.
I live about 10min from DFW airport. Be sure and bring a couple of cd's that you are familliar with. If you are a musician try to make it by on Wed night or Sunday afternoon when some friends and I get togehter play music. |
#1202 |
Hi Guys
Just a quick question - which is the best place in the Netherlands to buy Peerless 830875 Drivers and Peerless 810921/Scan-Speak D2608 Tweeters? I used to recall a company - but not their name - and been searching in vain for their website. Cheers, Joe R.
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" |
#1204 |
This is latest incarnation of my crossover with Jantzen inductors in the 1.8 and .33mh positions. In series with LF and MF pairs only as I felt the lower series resistance was more beneficial in these locations. They weigh about 2 or 3 kilos now. Lots of copper!
#1205 |
irext, still thinking of respinning those boards?
-- jk -- |
#1206 |
I do plan to redo them but it's fairly time consuming and I want to upgrade some of the components so I wont do a layout until I have all the parts that will comprise the final version. I want all the components to fit perfectly on the pcb. I'll post the layout once it's done in actual size so that anyone with a laser printer and some photo paper should be able to etch their own.
#1207 |
Hi all,
Quick pic of the speaker grilles i am using, I have a two year old son..... I cannot count how many times the speakers have been saved now....... Dan |
#1208 |
#1209 | |
What did you use to attach the mesh to the speaker?
-- jk -- |
#1210 |
Hi guys,
Yes they look a little like electro statics i think they sound nicer !I fix the grilles on with small screws through holes in the mesh, i have been meaning to replace them with black screws to match _Dan Sent from my HTC Desire using Tapatalk 2 |
| "Proac 2.5 clone" or "Elsinore project" | Joel Wesseling | Multi-Way | 10 | 26th May 2011 05:51 AM |
| A thread to post your "project files" | critofur | Multi-Way | 10 | 21st March 2008 12:50 PM |
| "compact loudspeaker factory visit from "magico mini" thread | Nanook | Multi-Way | 2 | 4th January 2008 07:30 AM |
| The "Really simple and cheap speaker designs for the newbie!" thread. | Spasticteapot | Multi-Way | 5 | 19th March 2006 04:16 AM |
