The "Elsinore Project" Thread - Page 102 - diyAudio
Old 15th November 2011, 01:42 AM   #1011
just another
wintermute's Avatar
a couple of posts were removed due to a racist term being present
Any intelligence I may appear to have is purely artificial!
planet10 needs your help: Let's help Ruth and Dave
Old 15th November 2011, 11:51 PM   #1012
tpate is offline tpate  United States
jdkJake, One caution on your rear port size. The 4" hole will be just a little bit wider than the internal back braces are, (4 X 25.4) if your braces are on the narrow side of 100mm the port tube will not fit between the braces especially if you are a little off center with your pilot hole. I'm sure you have thought of this but mine just barely fit.
Old 16th November 2011, 12:13 AM   #1013
Have new waveguides with rear pocket removed for easy and clean mounting.. 5 spoken for and 7 remaining $160can/pair. Off to paint soon
Decided to mount the tweeters a new pair tight and fill gap.. I like what I hear. gap or no gap? Can add spacers to experiment..
Either way I definately like the tweeter mounted to the waveguide..
Old 16th November 2011, 01:45 AM   #1014
jdkJake is offline jdkJake  United States
Thanks for the heads up. I noticed it almost immediately after assembling the rear panel. Just after it was too far past the point of compensation.
I have a plan...
-- jk --
Old 16th November 2011, 01:48 AM   #1015
Originally Posted by Joel Wesseling View Post
Decided to mount the tweeters a new pair tight and fill gap...
Tell us Joel, what did you use to fill the gap? Is that modeling clay?
-- jk --
Old 16th November 2011, 02:14 AM   #1016
I used plumbers putty. Had some in the house. The excess carves out nicely
Old 16th November 2011, 02:21 AM   #1017
Ah, that makes sense. A good choice as it should "never" dry out nor crack over time.
I look forward to your impressions of a gap vice gapless after an extended listening period.
-- jk --
Old 16th November 2011, 02:03 PM   #1018
I ended up using the flared end, or coupling from sch 20 pvc pipe, cut to 2 3/4" long for a port tuning of 33hz.
Old 19th November 2011, 01:25 AM   #1019
Default Even the blind squirrel finds a nut once in a while...
You've heard the adage "Better to be lucky than good", well, today I was lucky. VERY lucky.
Routed the holes for the ports. Used a router to start the hole and get a clean surface transition. Finished the job with a 4 inch hole saw.
So, how close to the back stiffeners did I get?
Whew!
-- jk --
Old 19th November 2011, 01:29 AM   #1020
Default Holes and more holes...
Front panel holes are finished. Love that Jasper jig!
Anybody need any holes? I am getting quite a collection.
-- jk --
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 05:51 AM
A thread to post your "project files" critofur Multi-Way 10 21st March 2008 12:50 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
Copyright 1999-2017 diyAudio
