Hello
Not a very good thread title. Sorry. I'm part way through making some more curved speakers. I've got as far as building an MDF frame, skinning it with bendy MDF and layering up some fibreglass and sand mixed with polyester resin. So far so good, they are fairly dead and there isn’t a lot of chance of them flexing much at all thanks to 5KG of resin, 4 layers of thick matting and ½ bag of sand in each. However, I want to do as much as possible to reduce cabinet resonance so was wondering if it's advisable to put in a soft layer, I was thinking about something like upholstery foam, with another couple of layers of fibreglass on top? Good idea or not worth bothering? Is there anything better to use / do? |
#2 |
Custom Title
Yes, it's a good idea, as long as you can compress the soft layer effectively- it'd be a shame to add the extra layer just to have it start resonating from the stimulus of the output from the speaker.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#3 |
Quickshift,
"more curved" got my attention. It means you can get the horn to support the upper bass/lower mids a low Q driver can't do alone - but it doesn't attenuate unwanted midrange smut. Calculate the standing wave that might build up in your cab's width. Hanging a layer of felt in the middle of your horns ("hanging" means it halves the width, you look at the edge of it - s**t, I couldn't even explain it in German without using my hands) might be a good idea. Anyway, whatever you do - keep one side panel unglued until you are really happy. There is nothing as as "I ought to have tried that"Cheers, Pit |
#4 |
OK, thank you badman
I'm not sure how I'd compress it though. I'll have a think on it. |
#5 |
I understood perfectly pit
I'm not building horns though, just simple sealed boxes for some woofers. There is nothing as as "I ought to have tried that" And nothing as |
#6 | |
Pit
#7 |
A good point well made
I was remembering the time I spent about an hour removing contact adhesive from some speakers I'd botched a veneering job on using petrol and a chisel A very |
#8 |
Ermm...*polite cough*...were there any planes or 90° left when you were done?
#9 |
Yeah - it all came good in the end - luckily I'd soaked the outer layer of hardboard with Bonda wood hardener so it wasn't as bad as it could have been - tough stuff Bonda...
Today I have been considering if I should have another go |
| Cabinet in layers | kvk | Full Range | 22 | 12th March 2008 08:59 PM |
| internal cabinet damping gloop | jives11 | Multi-Way | 6 | 5th July 2006 09:29 PM |
| Creepage distances in PCB internal layers | Jaka Racman | Power Supplies | 6 | 26th October 2005 02:34 PM |
| cabinet construction | tenderland | Full Range | 16 | 9th January 2005 02:52 AM |
| Cureved loudspeaker construction page started | Andy G | Multi-Way | 33 | 31st January 2004 11:57 PM |
| Page generated in 0.12121 seconds (71.92% PHP - 28.08% MySQL) with 10 queries |
