Old 25th February 2007, 05:40 PM   #1
Default Tapering TL-speaker, why?
I have spent many hours on the web to gather information about TL's. Regarding tapering I have read different opinions.
Some say the taper will reduce the standing waves within the enclosure. That's obvious but I think you could get the same result by making the walls nonparallel as with a circular tube.
Some say a tapered line can be made more compact. Some say it effects the width of resonance. So......
1) could I make a decent TL without taper? (most commercial ones are tapered.....)
2) Does a strong taper make the TL sound more like a closed box?
I've got rather small units of 13 cm so the size of the TL will be moderate, tapered or not.
Thanks!
drs M.J. Dijkstra
Tapering a transmission line...with styrofoam? Would it work? Spasticteapot Multi-Way 4 1st November 2006 07:21 PM
Bessel Or power tapering? 24kilo Multi-Way 13 2nd October 2005 04:57 PM
Is my power tapering wired correctly? GuyPanico Multi-Way 8 6th June 2005 01:25 AM
TL Tapering - quick question bigwill Subwoofers 26 28th April 2005 04:35 AM
Help with Line Array wiring_Power tapering sqlkev Multi-Way 20 24th July 2004 07:32 AM
Page generated in 0.06475 seconds (69.16% PHP - 30.84% MySQL) with 10 queries
