hi, what do you think about this driver in a 20 ltr bass reflex enclosure.
it's for listening electronic music, jazz, and some rock. so for electro music, i need deep, clear, precise and detailled bass and mid . and wich kind of tweeter can i put with this driver? thanks a lot. |
#2 |
At what freq do you plan to cross?
#3 |
i think near 2000/2500 Hz.
do you think it's a good choice? |
#4 | |
#5 |
i'm sorry but i don't understand what do you mean, my english is not good enough, do you mean i need to cross it more higher?
#6 |
He means steeply,
babelfish gives me 'en pente rapide' |
#7 |
an excellent mid/bass driver, but for electronic music I don't think it goes low enough, for satisfactory lows I think you need a response down to the low 30s. This driver with a sub of some sort would be an excellent arrangement (or a 2.5 way).
As for tweeters, Peerless make good ones, as do SEAS, I'd probably use one with a low FS so you can cross over around 2Khz SEAS 27TBFC/G is a very good choice |
#8 | |
En tout cas, la frequence de 2000 Hertz est bien choisie, mais vous voulez une pente de 24 dB/octave sinon vous allez avoir des pepins aux alentours de 4 kHz parce que la reponse du woofer sera de trop, meme apres le crossover. Ceci dit, je vais me taper un verre de vin de Californie. Sante! |
#9 |
#10 |
Thanks for all these good informations.
I think i'll build these one, and maybe if i want more bass, build a sub.((-i' have just finished two fullrange with sph-60x from monacor, good definition of the sound but under 60hz the bass are really really bad-)) Sreten, thanks for the url, many good things about the filter. now i have to work... DSP_Geek, merci pour l'explication en français... c'est plus clair, (i have to work my english !!) Just one other question, about the phazing, how to calculate, where do i put the drivers? And for the cabinet design, i've read on the web that it's better to have a deep cabinet and a not too large front baffle, it is right? |
| Need Woofer advice for a 3-way project | boywonder | Multi-Way | 3 | 4th January 2008 11:48 AM |
| Woofer advice sought | cs | Multi-Way | 7 | 29th January 2007 09:08 PM |
| Advice on a small mid-woofer. | cyclo | Multi-Way | 6 | 28th April 2005 12:53 PM |
| 12" woofer advice | Duck-Twacy | Multi-Way | 21 | 18th March 2003 01:27 AM |
| Page generated in 0.09755 seconds (79.93% PHP - 20.07% MySQL) with 10 queries |
