I am going to be making a line array of about 25 4" woofers and 25 5/8" tweeters. NSB's with onkyo's. Do I need componants for each driver (an inducter for each woofer and cap for each tweeter) or just one set each for the summed pairs? Some sort of electronic crossover and seperate amps would be ideal I know, but funds are limited. Thanks for any help.
#2 |
Speakerholic
You need only the components you would for one driver, not for each.
Let's see...25 X 4" = 8 '4" without factoring in the cabinet or driver spacing. Do you have tall ceilings? |
#3 |
You don't need/want individual crossover components for each driver - they will have an additive effect on each other. The same crossover circuit can be connected to any number of drivers - the trick is wiring the drivers together so that you maintain the desired level of resistance seen by the crossover/amp.
This project at PartsExpress, though it has no actual crossover, will give you an idea about driver wiring in a line array: http://www.partsexpress.com/projects.../Kuze3201.html
Soft Dome |
#4 |
go to zalytron
find line arrays, see the wireing diagrams for inspiration passive crossover is fine when done right |
#5 |
Wowzers, 25 per side?
When I finally get around to building mine (been sitting on the drivers for over 2 years now) I only plan on 12 per side. I had originally planned 14, but 12 is easier to wire.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#6 |
Sorry, I mean 18 nsb's and 25 onkyo's . They will be about 7ft high with a base. I am going to give the nsb's a few coats of laquer and mod the onkyo's to get them as close together as possible and remove the phase shield. I might taper the ohms of them, but getting somewhere near 4 ohms might be just confusing enough. I'll post a picture of them when I'm done in a couple of weeks or so.
| Line Array question | aceinc | Planars & Exotics | 20 | 13th October 2009 11:03 AM |
| Crossover frequency selection for line array | goldyrathore | Multi-Way | 5 | 13th June 2009 08:28 PM |
| LINE ARRAY question ? | nickthevoice | Multi-Way | 7 | 7th February 2008 12:24 AM |
| Line Array Crossover | PrimaLuna | Full Range | 7 | 19th February 2006 03:50 AM |
| Line Array / multiple driver crossover design | awdtalon92 | Multi-Way | 2 | 26th March 2004 07:49 PM |
| Page generated in 0.10213 seconds (76.87% PHP - 23.13% MySQL) with 10 queries |
