I have a set of drivers for the Rega Naos speakers. I was wondering if anybody knows any information on them. All I know is the external dimensions and that they are a quarter-wave TL design. I was going to use them in my own design but I don't have test equipment (as of yet and in the works) so what I would like to do is try to stick close to the original design. Any info would be greatly appreciated.
Thanks Fred |
#2 |
An educated guess is internally they are very similar to many designs. Internally the may look like this : (except with a rear opeming not top) An Extremis 6.8 Offset Reducing Taper TL Design Or likely very like this : http://seas.no/kit/Thor%20cab.pdf With the external dimensions you will not go too far wrong. A friend had a pair of Naos. Pretty good, but not in my book for £1K. You will need the crossover details. |
#3 |
Thanks a lot for the info, that was the way I was leaning, but... Where is the port opening? In your post you say not at the top, but how do you have a top mounted driver, one fold and have a different than top port (or do you just mean at the rear, like in the second design).
I figured it's worth a try, I got the drivers cheap enough. Cheers, Fred |
#4 |
like the 2nd design - do you have any c/o details ? |
#5 |
Very little right now,
I am kindof taking it one step at a time, but I know they used a very simple crossover design. With your suggestions and some more searching, I have found enough info to put together a rough design for the box anyway. Thanks |
| Eagle vs. Sprint-Layout for PCB design/layout | hollowman | Parts | 9 | 9th July 2011 04:34 AM |
| Class C PCB Layout and design software | AudioGeek | Class D | 5 | 25th October 2007 02:08 AM |
| Board layout design | Valvomaniac | Tubes / Valves | 7 | 21st March 2007 01:08 PM |
| Track layout design | elaar | Solid State | 18 | 18th November 2006 03:19 PM |
| Short Thor Internal Layout | imjatse | Multi-Way | 6 | 28th April 2006 02:31 PM |
| Page generated in 0.08859 seconds (74.48% PHP - 25.52% MySQL) with 10 queries |
