Old 21st February 2007, 06:23 PM   #1
RobWells's Avatar
Default Closed back midrange drivers 4" maybe 3" - recommendations please
Hi All,
I've been looking for a midrange to do from anywhere between 200 - 500Hz up to 3500Hz. Preferably with a closed back or that works in an enclosure only big enough to sqeeze in the basket.
Its for a future car project, but 8 ohms is fine.
Any ideas ?
Rob.
Old 22nd February 2007, 12:49 PM   #2
Paradise_Ice's Avatar
Default Re: Closed back midrange drivers 4" maybe 3" - recommendations please
Originally posted by RobWells
Hi All,
Any ideas ?
Rob.
Depth is the only problem in a car I think, some mid-woofers come with sealed plastic cups that give them the correct vas.
you can just use a nice smaller woofer and cross it over at the higher Hz that you want?
Vifa have some nice 3 or 4 inch drivers with a good flat response.
Old 22nd February 2007, 04:59 PM   #3
RobWells's Avatar
Thanks Ice,
These are the ones I've been looking at so far, but I haven't modelled yet to see the box sizes.
Peerless 830516 4"
Peerless 830856 3.5"
Vifa m10md 4"
Audax hm100z2 4"
Audax hm100c0 4"
Size isn't too important as they're going to be on a door build. The midbass will use the door as a box (Peerless 850518) and the midrange and tweeter will sit above, with the mid having its own chamber.
I've also got to source a fairly small tweeter to do ~3500 up.
Rob.
Why do some commercial speaker use 7" drivers for midrange? Bogwan Multi-Way 6 5th March 2008 11:30 AM
Dynaudio Esotec D-260 Tweeters with D-76AF 3" Dome midrange drivers FSHZ:42 Multi-Way 1 2nd October 2007 02:07 PM
Recommendations for 6.5-8" woofer/midrange as a dipole Samppo Multi-Way 11 3rd October 2006 12:55 PM
Vifa M17MH 7" paper midrange drivers JohnR Swap Meet 0 29th May 2002 01:10 AM
Page generated in 0.07143 seconds (67.78% PHP - 32.22% MySQL) with 10 queries
