Old 21st February 2007, 12:28 AM   #1
Default How To Add Rear Tweeters to System?
Hello to All:
I am toying with the idea of adding rear tweeters to
my speakers (2-way 6.5"/.75" TL, nominal 6-8 ohm) to
try and improve depth & spaciousness, and have some
general questions for anyone who has ideas:
1. Where to cross over (frequency) the rear units?
2. Firing straight back, or up at an angle?
3. Wide or narrow directivity pattern?
4. Wired out of phase with front tweeters?
5. Any problems connecting them in parallel with main
speaker system at amplifier (B&K ST-140 MOSFET)?
Many Thanks in Advance!
Fastcat
Old 21st February 2007, 12:35 AM   #2
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Default Re: How To Add Rear Tweeters to System?
Originally posted by fastcat95
Hello to All:
Fastcat
1. 7kHz, play with level.
2. Up at an angle.
3. Wide.
4. In same polarity.
5. Lessens impedance at HF, no problem with solid state both for 4 & 8 Ohm speakers (see published two last octave Z). For valves avoid on 4 Ohm speakers.
8inch woofer rear loaded horns with tweeters Naudio Full Range 1 10th January 2009 09:54 AM
Rear tweeters bzfcocon Multi-Way 6 12th February 2008 07:22 AM
how to avoid transmission line resonance with front and rear firing dipole tweeters? thadman Multi-Way 7 14th June 2007 07:09 PM
Rear Mounting Tweeters ralph-bway Multi-Way 6 15th January 2005 07:11 AM
Possible to use the Hexadym magnet system in drivers other than tweeters? 454Casull Multi-Way 2 9th May 2004 12:32 PM
Page generated in 0.07132 seconds (70.36% PHP - 29.64% MySQL) with 10 queries
