I was interested in using this design and placing one on either side of a flat screen TV ...on- wall for dual center channels because I can't fit a single one under or over the TV.
Has anyone listened to this design? Would I need to modify the crossovers if I ran 2 of these in parallel? I assume if I built the complete crossover for each one that no change would be required. The single design is fairly low efficiency so running a pair should help. Thanks! |
#2 |
What I meant to suggest was that a single crossover may be a more effective way to run a pair of these in parallel.
Maybe the creator or someone else has already done this exercise? |
#3 | |
If you want higher efficiency, I reccomend a pair of the $15/pr soft-dome tweeter (I think they're the same as the PE "Meiloon" buyout tweeters) on the ApexJr website. I can testify to the awsomeness of the vendor, and $7.50 for a decent-quality 96db/w tweeter is nothing to sneer at. If you can find some of the so-called "NSB" uber-cheap midwoofers, there are a few designs that should work very well - the UBHTs are supposed to be marvellous for the dollar. http://www.partsexpress.com/projects...ects.html#ubht |
| My build of ZaphAudio 2 cu.ft Dayton RSS 12" HF Sealed Sub | Choots | Subwoofers | 36 | 24th January 2011 12:22 PM |
| Couple ZaphAudio ZD5 questions | caz | Multi-Way | 2 | 11th July 2009 02:37 AM |
| Finished Zaphaudio b3s project :) | jaygeorge1979 | Multi-Way | 37 | 20th March 2006 04:02 AM |
| FYI: ZaphAudio new ribbon tests | mbutzkies | Multi-Way | 80 | 15th December 2005 11:16 PM |
| Page generated in 0.07015 seconds (76.17% PHP - 23.83% MySQL) with 10 queries |
