hi, what do you think about a driver with a qts of 1.7 or more?
i want to build a 20 liter bass reflex box, is this driver good for it? more info on driver here thanks a lot and sorry for my english |
#2 |
What you need is a negative output resistance amplifier see this thread and scroll down to posting #9
I want to make an amp with a Negative Output Resistance, but HOW?? |
#3 | |
Regards Charles |
#4 |
Did it Himself
I think this driver is for open-baffle guitar use or something. As said you need to lower Qts by negative impedance, or use a sealed box and Linkwitz Transform.
Personally I would just get a more suitable driver.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#5 |
ok, many thanks, i think i'll see for another driver.
| Power supply:Universal AC input/ Full range,High Efficiency, and High reliability | hang | Vendor's Bazaar | 12 | 24th July 2009 03:46 AM |
| Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. | kimbal | Tubes / Valves | 4 | 11th May 2009 08:05 PM |
| I coined the phrase HIGH VIVIDITY, to differentiate our amps from High Fidelity ones | vax9000 | Tubes / Valves | 8 | 31st October 2006 01:10 AM |
| 6BY5 High Voltage & High Current Choke Input Design P.S. | snoopyma | Tubes / Valves | 7 | 28th June 2006 01:32 PM |
| high gain 2nd order high pass active filter topology | sreten | Solid State | 21 | 23rd March 2006 01:26 AM |
| Page generated in 0.07635 seconds (72.21% PHP - 27.79% MySQL) with 10 queries |
