Old 20th February 2007, 02:35 AM   #1
Default 2.5" driver recommendation
Hi guys,
I have some left over 1/2" birch plywood from a cabinet I built and I want to make some small computer speakers.
I am looking for a driver that is smaller than the Hi-Vi B3s preferably. Sound quality isn't a big issue. I just want something that will look cool and function in a near field environment at low volume. Lets assume I can do a digital crossover to a reasonable sub at 150+ hz.
Any cheap drivers out there that I might be able to play with? I will probably power these with an older sony stereo receiver. They need not be loud or perfect.
Thanks!
~Nathaniel
Old 20th February 2007, 08:54 AM   #2
Dag is offline Dag  Sweden
Dag's Avatar
Check out zaphs tests at
http://www.zaphaudio.com/smalltest/
http://www.zaphaudio.com/minitest/
Old 20th February 2007, 11:04 AM   #3
http://www.partsexpress.com/pe/showd...number=264-830
possibly, /sreten.
Old 21st February 2007, 02:21 AM   #4
Thank you both for the links.
After reading Zaph's tests it looks like there really aren't "useable" drivers out there under 3". Is there anyway to get decent performance out of the B3S in a small enclosure? I am thinking something along the lines of 1 - 1.5l?
What driver properties would indicate decent performance in a small enclosure?
Old 21st February 2007, 03:13 AM   #5
holdent is offline holdent  Canada
Zaph's "Hi-Vi B3S single driver system" (http://www.zaphaudio.com/audio-speaker18.html) enclosure is small but more like 3.75 L by my calculations. I quickly modeled the B3S in three sealed enclosures sizes; 1.0 L, 1.5 L and 2.0 L. There are trade-offs in bass extension at these smaller sizes (particularly the 1.0 L and 1.5 L) that may make subwoofer integration even more problematic (Zaph has a very good analysis of this problem in the link above). If I were you I'd stick to the larger box size Zaph uses.
BTW I bought the round flange version, the B3N, from Madisound and they are very attractive, great sounding, and surprisingly small drivers. I think they are a great deal.
Old 21st February 2007, 03:20 AM   #6
I am listening to a pair of Zaph's B3S speakers now :-)
I am really looking to go smaller so that they could go on the desk in my office with a little footprint. I am valuing looks over performance here. I guess I should try some modeling and see what I come up with. The round Hi-Vi's might be a good option.
Too bad the A2S has such poor response. I think I could do something cool with a speaker that size.
Old 21st February 2007, 10:15 AM   #7
Zaph is simply lazy in re-using using those boxes
- they are not designed volumes for the B3S.
Using Zaph measured Vas for the B3S indicates 1.5L will be fine.
Box depth can be reduced, hieght somewhat, keep width the same.
Follow Zaph design and use the near field filter options, you can't do better.
/sreten.
Old 21st February 2007, 10:25 AM   #8
with Vas = 0.8L problems only start at < 1L.
/sreten.
Old 21st February 2007, 11:44 AM   #9
Thanks Sreten, I think I will do just that. I will post up some pictures when I finish.
Old 21st February 2007, 01:30 PM   #10
I am thinking of something with this shape. Internal volume of 1.528 Liters accounting for the back of the driver. Zaph's near field filter outside the speaker under the desk.
Not drawn exactly to scale. The baffles external dimensions would be 13.5 x 13.5 cm
Thoughts?
Driver recommendation please jaybird Subwoofers 2 26th February 2009 11:40 AM
Driver recommendation for midrange in 3 way active. 5 1/4 or 6 1/2 inch? rhythmdiy Multi-Way 16 24th October 2007 09:19 PM
Recommendation for 10" sub driver? weinstro Multi-Way 2 1st April 2006 06:51 AM
in need of recommendation for a mid-bass driver piro Multi-Way 4 4th June 2004 08:06 AM
Recommendation for sub driver UK DNRC Subwoofers 46 22nd January 2004 01:38 AM
Page generated in 0.11713 seconds (79.96% PHP - 20.04% MySQL) with 11 queries
