How do you check for leaks?
Old 10th January 2003, 02:27 AM   #21
Santoso is offline Santoso
Guys,
Check out the 2nd paragraph http://www.speakerworkshop.com/SW/Pr...r%20Sealed.htm
Old 14th January 2003, 02:13 AM   #22
viper073 is offline viper073
Originally posted by Pjotr
Leakage only lowers the total Q of the box. In some occasions this can be even of advantage. One of the nasty things of leaks is the “breathing” sound or noise they can generate.
Thanks guys!
Im sure Ill find a way now to see if theres any leaks. Im pretty sure theres not, but its always good to check.
Actually the reason I ask is because I think my sub is sounding a little boomy.
I built a 12inch shiva subwoofer with a 150w amp mounted external to the box. My box volume is 60 liters and is packed with stuffing. According to the design, a box volume of 54 liters would give a Q of .707. I made mine a little bigger to lower the Q, to get a less boomy sound. I was interested to hear that a leak would actually lower the Q (I guess it makes sense though)
Ive tried changing location of the sub without much success. I am now thinking of hooking up a potentiometer to one of the coils to control its stroke.
Does anyone have any suggestions what else to try before I open up my box again?
If my amplifier has a bass boost, would this make it sound boomy?
How do you check for leaks?Hide this!Advertise here!
Transformer Hum leaks to Speakers kff322 Tubes / Valves 16 17th January 2007 11:01 PM
Air leaks in horns xcortes Multi-Way 6 20th August 2004 04:48 PM
Arrggg Leaks!!! RyanC Multi-Way 10 6th June 2004 12:42 AM
Searching for Leaks (aka !@#$) Nappylady Multi-Way 8 20th February 2003 11:59 PM
