I have some old vifa 5" lying around. I plan to make a small bookshelf with them.
I can not find any paramaters for this driver. Driver is Vifa P13WH-99-04. I bought them about 10 years ago. Have used them as midrange i a 3-way. I suspect they are similar to the P13WH-00-08. Does anyone have the t/s parameters for this driver? |
#2 |
I dont know if the P13WH-00-08 parameters is the same, but here they are:
FS 60 Hz Qms 1,38 Vas 10 liters Cms 0,95 mm/N Mms 7,5 g Rms 2,02 kg/s Xmax 4 mm Sd 88 sq sm Qes 0,43 Re 5,53 Ohm Le 0,7 mH Z 8 Ohm BL 6 Tm Pe 40 watt Qts 0,33 Spl 88 dB Maybe somone knows what the -99/-00 means?
Norcad |
| Little help needed - Vifa MG18 + Vifa DX25 - 2.5way | guitvinny | Multi-Way | 12 | 10th May 2009 10:18 PM |
| Vifa Xt25 + P13wh + Dayton RS180-8 your thoughts? | K-amps | Multi-Way | 14 | 25th July 2008 05:51 PM |
| Vifa XT25 and 2 x P13WH-00-08 project | fury | Multi-Way | 8 | 25th May 2008 12:38 PM |
| Bookshelf with Vifa P13WH-00-08.... | barackuda | Multi-Way | 7 | 23rd October 2006 09:13 PM |
| Page generated in 0.06893 seconds (65.51% PHP - 34.49% MySQL) with 10 queries |
