Old 16th February 2007, 02:23 PM   #1
jaste is offline jaste  Sweden
Default Splitting a ducone?
Hi! I was thinking about building a small two-way Tangband speaker when i saw this
http://www.blueplanetacoustic.de/pdf/18/DUCONE.pdf
Do you think it might be possible to split it in half and keep half the internal volume and just one rectangular port if you just want to use one "woofer" per box?
Old 16th February 2007, 03:06 PM   #2
badman is offline badman  United States
Custom Title
badman's Avatar
Default Redesign
You'd have to adjust the crossover to make sure the sensitivities match, and the baffle step lines up right. Better to leave it as is, if it's a good design.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 16th February 2007, 03:54 PM   #3
Speakerholic
Cal Weldon's Avatar
I second what badman said but if you must, it's probably OK to split the box and redo the XO.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Splitting AES/EBU Signal KCCT82 Digital Source 21 9th January 2008 10:17 AM
Pre-Out Splitting Bigred Solid State 15 13th July 2007 06:27 PM
Splitting up the Power Amp spuloo Tubes / Valves 1 30th June 2007 03:26 PM
Splitting ground Vivek Everything Else 13 22nd August 2002 03:29 PM
Page generated in 0.07148 seconds (72.84% PHP - 27.16% MySQL) with 10 queries
