Old 15th February 2007, 10:41 PM   #1
Gollum is offline Gollum  Canada
Default Moving a port to front
I'm the guy building the BAMTM at this thread . My question is simple : is there any impact on the frequency response to move the port from the back side to the front ? I know it's not a good idea to place the port right behind a woofer because too much midrange will come out. But what about placing it on the baffle instead of the read panel ?
Thanks for your time !
Dino
Old 16th February 2007, 03:50 AM   #2
GM is offline GM  United States
GM's Avatar
Greets!
Depends on the design. Not seeing enough info to say what all differences there may be, but most vents are on the baffle and can be damped as required if they contribute too much audible BW.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 16th February 2007, 10:07 AM   #3
http://www.zaphaudio.com/BAMTM-cad-vented.pdf
Are you following this ?
By his own admission box design is not Zaphs forte.
Why do you want to move it to the front ?
/sreten.
Old 16th February 2007, 01:39 PM   #4
sreten,
it's exactly what I'm building, but with on small change : the baffle won't cover the top half of the cabinet only, it will go from top to bottom, 44" long.
The only reason why I want to put it on the baffle is the look. I plan to place it around 12" from the base. Does it sounds like a bad idea ?
BTW, maybe Zaph is not that good with box design, but I've learned on this forum that you don't change a design if you don't know what you're doing... and I'm not sure I do right, so I need help here !
Thanks for your time,
Dino
Old 16th February 2007, 02:00 PM   #5
Well the bracing arrangement in the box could be improved.
If the box is completely lined with foam etc including the front part
then port front or back 12" from bottom will not be critical. You can
then tune the bass to a degree with the amount of light stuffing
placed in the top half of the enclosure.
Good luck with it - seems a great design for the price.
/sreten.
Old 16th February 2007, 05:08 PM   #6
sreten,
you won't go away so easily ! Please explain yourself, I need to learn !
1) What can be improved in the bracing arrangement ? The more the better, no ?
2) I don't plan to stuff the cabinet too much. In what it changes something to port placement ?
regards,
Dino
Old 17th February 2007, 06:39 AM   #7
How much in duty have you guys had to pay when ordering stuff from the US? I am trying to figure out if it will be easier to try and find stuff in Canada or just order from PE or Madisound.
Shawn
Old 17th February 2007, 07:48 AM   #8
Geek's Avatar
Hi Shawn,
Most items are NAFTA duty free. Have them send it USPS instead of courier, because a courier will nail you a fair hefty brokerage fee wheather there's duty on it or not.
The most I have been hit from post is the odd $10 "handling fee" fron CCRA. But this only happens when they send it under my company name.
As for the topic, front ports are MUCH less critical with room placement. You lose some bass "room gain" with the port on the front, but you won't spend an hour looking for the spot where your bass doesn't sound like mud either
Cheers!
Old 17th February 2007, 11:37 AM   #9
318Shawn,
With my current project (Zaph BAMTM), I've ordered from Madisound and Parts Express. Both were send via USPS Airmail. Here is the breakdown of each order:
Madisound: (value of duty: 135$)
Duty: 0$
Excise Tax: 0$
GST/HST: 8.15$
PST: 10.80$
Handling fee: 5$
TOTAL: 23.95$
PartsExpress: (value of duty: 52$)
Duty: 0$
Excise Tax: 0$
GST/HST: 3.12$
PST: 0$
Handling Fee: 5$
TOTAL: 8.12$
You always pay Handling Fee and GST (6%). I don't know what is PST though... and as Geek said, forget UPS or FEDEX from USA, except if the sender gives you the insurance he covers all the charges.
Hope this help.
Geek,
Since the speakers won't be placed in the best spot, I think you have a good point. Room gain from placement will be good enough without adding more with port.
Thanks for your help,
Dino
Old 17th February 2007, 04:46 PM   #10
Thanks for the info guys, sorry to hijack the thread.
Shawn
Rear port and front port barry.childs Multi-Way 10 27th February 2009 09:46 AM
Port front or back?? SamClassA Multi-Way 4 8th November 2006 10:59 AM
front or rear port blu_line Multi-Way 3 12th March 2004 01:20 PM
rear port vs front port Jimmy154 Multi-Way 22 6th March 2004 08:38 AM
Rear vs. Front Port squidbait Multi-Way 11 21st January 2004 12:10 AM
Page generated in 0.12269 seconds (80.91% PHP - 19.09% MySQL) with 10 queries
