cone-feed? or 3"x6" rectangular horn?
which sounds best overall and is easier to deal with crossover-wise? consideration of possibly going into a Karlson might be taken into account I'm used to 3"x6" horn on Eminence and they're no picnic :^) |
#2 |
I've only tried the cone style, so I cannot compare but it sounded pretty nice to me, next time I will use a variable l pad in the cross over design so that it ca be easly talored for different rooms. Its no tannoy but it was nice sound overall for its price.
#3 |
Hi Cameron - which model did you try and where were its difficiencies? was it harsh in places?
Best, Freddy |
#4 |
It was a few years ago so I grabed my copy of the catalogue. It looks like it was the CXA, I liked the sound it had, a definite peak at 3.5 which perhaps should have been delt by my xo better.
Looking at p audios sheets, there A class 300cf complete speaker with box appears to use the horn BM15cxhb. it seems to have quite a flat response. I think I will try this driver next. Like many p.audio speakers there tight surround makes it a little light on bass, but the upside would be that it makes them very hard to distroy with a simple mistake. |
#5 |
what seemed the harder part to tame in 15CXA - woofer or HF?
15CXHA looks a lot like the old Eminence C15CX - mine sounded better with a disk of foam over the little horn spider to catch some HF spikes PSD2002 input impedance on 3"x6" C15CX horn http://img242.imageshack.us/img242/7619/tweetzwcg3.jpg C15CX SP15 type cone woofer impedance in a Karlson box http://img242.imageshack.us/img242/158/woofzwnj8.jpg C15CX smooth cone woofer impedance in RCA-Fan's V-vent box http://img135.imageshack.us/img135/2082/c15cxqj6.jpg C15CX with CD8 rear view http://img408.imageshack.us/img408/1083/coaxrjpgxx7.jpg C15CX with Sp15 type cone front view in a coupler http://img183.imageshack.us/img183/1...xft1jpgul8.jpg 15 Inch Coax with EV-SP15A type cone :151043 (MCM) 01-SPEC 151043 04-DATE 01/07/93 02-PART # OBS/55-1125 03-MODEL # 1530F9537 05-RE OHMS 6.34 06-LE MH .76 07-QM 7.15 08-QE .380 09-QT .360 10-XMAX MM 2.90 11-BL TM 18.03 12-EFF % 6.05 13-FS HZ 53.38 14-MMS GMS 58.26 15-CMS mm/N .1526 16-RMS NS/M 2.7340 17-VAS LTRS 157.15 18-SD SCM 856.34 19-EBP 140.1 20-SPL dB 99.8 |
#6 |
i'm very interested in this as well...for my own K15s. they're sitting incomplete and i'm not sure what direction to take them in. I'm leaning towards either a P-Audio coax or a 3-way active setup with Smith horns on top. If i go the coax route i wouldn't be sure which fo the two P Audio drivers to get...
by the way freddy, have you experimented much with port tuning in K15s? i remember you posted about using some PVC elbows on a plate instead of the stock port to bring the tuning down...how might this affect performance up to about 800ish hz? if at all? |
#7 |
that K15 was re-tuned to ~exemplar spec to play (boosted and with xover) down to 18-20Hz using low fs Altec and that would probably unbalance its normally ripe midbass. K15 makes a nice sub in that guise.
#8 |
18-20 hz would be an amazing thing to achieve, but probably a little excessive for my purposes. I would be happy with 40 or 45 hz...i mean 30 or 35 would be great too but i imagine there would be some compromises to be made. about how low can you take a stock K15 anyway with a decent driver?
#9 |
outdoors in my yard which drops off, F6 is around 55Hz relative to 100Hz with Altec or EV -- going "deep" isn't a K's strength
| Jericho horn speakers with Audio Nirvana Super 8" | hagr | Full Range | 37 | 2nd May 2009 11:38 PM |
| Hemp 8" Coax and Tractrix horn? | bambadoo | Full Range | 4 | 25th May 2007 06:13 AM |
| Coax tweeters: unwanted horn loading? | Klimon | Full Range | 2 | 7th September 2006 10:18 PM |
| Back Loaded Horn with Pro Coax Driver | djdan | Multi-Way | 10 | 15th October 2004 01:45 PM |
| Page generated in 0.10239 seconds (80.35% PHP - 19.65% MySQL) with 10 queries |
