Old 13th February 2007, 10:39 PM   #1
Default any suggestions for small faceplate tweeters
I am planning a project which will require a tweeter with a compact faceplate.
I have been looking at the Morel MDT40 or MDT44 as I want to be able to cross fairly low. Anyone have experience with these Morel units or other similar ?
http://www.partsexpress.com/pe/showd...number=277-042
JM
Old 14th February 2007, 01:20 AM   #2
Tenson is offline Tenson  United Kingdom
Vifa D26NC55 without a doubt. Asked the same question a few weeks back. I believe ATC used this tweeter in their SCM20-2, SCM10-2 and T16 speakers.
Old 14th February 2007, 04:16 PM   #3
Default higher Fs
I saw the test results on John K's site and thought about this Vifa D26NC55 and the price is good.
It has quite higher Fs than the Morel so would limit crossover to above 2.5k I think. Also I see that Madisound is out of these for some time.
Would still like to hear from someone who has used/heard the Morel MDT40/44 please..
JM
Old 14th February 2007, 04:37 PM   #4
Fs does not necessarily indicate the best c/o frequency.
Smoothest and most extended response curve in the group, and resulting CSD is excellent. Good tall order HD above 2kHx, but average 2nd order HD. Poor HD levels of all types below 2kHz, even considering the extended low end. It may have a 500 Hz Fs, but don't think about crossing it below 2kHz LR4 or 2.5kHz LR2.
/sreten.
Old 14th February 2007, 11:03 PM   #5
I think Solen have stock.
Suggestions for a small room? StoneT Full Range 4 25th October 2007 02:08 AM
95mm or smaller faceplate tweeters gtphill Multi-Way 0 30th June 2007 03:06 PM
Suggestions for the TB W8-1363SA small box sub? Jim McPherson Subwoofers 23 9th February 2007 05:11 AM
Suggestions for small 2-way system? BorisH Multi-Way 3 28th March 2005 06:32 PM
best tweeters in small size maxxx Multi-Way 1 7th March 2004 04:53 AM
Page generated in 0.39918 seconds (4.34% PHP - 95.66% MySQL) with 10 queries
