Old 13th February 2007, 02:25 PM   #1
Default Parts express Totally tubular questions.
HI all,
I saw this project on Parts express' website and i thought it was very interesting.
http://www.partsexpress.com/projects...lar/index.html
I was wondering if it would be possible to change these to a sealed design. I planned on using a sub with them as well as an active crossover. I like the idea of an MTM design using pvc its just a cool looking design.
thanks.
-Brian
Old 13th February 2007, 03:29 PM   #2
Of course you can make them sealed, you can also
reduce the length of each pipe by 50% if you want.
Active crossover - your going to need it as the crossover design is
poor and the speaker apparently has no baffle step compensation.
checkout : http://www.zaphaudio.com/BAMTM.html
/sreten.
Old 13th February 2007, 06:48 PM   #3
sdclc126's Avatar
/sreten.
Hi streten - how would you correct the crossover design (passive) on the TT? Thanks.
Soft Dome
Old 14th February 2007, 03:09 AM   #4
what BSC would be needed? as designed, there is a minimal "baffle" so i would think there is minimal effect, and only an effect on the higher frequencies right? Im new to diy speaker building so let me know if im wrong....
I thnik for those particular drivers a .5 cu ft box per speaker is recommended, so basically... pi*(R)squared*length = volume using a 6' pvc pipe.....
3.14 *9*x=.5
x= about 2 inches? seems a bit tiny to me.. lol
i was thinking of a 6 inch pipe about 5 or 6 inches long would be a nice space conserving size. idk how well it would be acoustically though.
Old 14th February 2007, 09:48 AM   #5
Originally posted by sdclc126
Hi sreten - how would you correct the crossover design (passive) on the TT? Thanks.
I'd use Zaph's data and the methodology outlined here :
http://www.rjbaudio.com/Audiofiles/FRDtools.html
/sreten.
Old 14th February 2007, 10:18 AM   #6
3.14 *9*x=.5
1) - no. The speaker is the baffle, ripple and step are relatively severe.
2) 0.5cuft = 12*12*6 = 864 cubic inches internal.
A 6" internal pipe = 30.5" long.
/sreten.
Parts Express - UK Equivalent? wilky Multi-Way 4 7th September 2008 08:32 PM
Usher 2 way at Parts Express Rizznits Multi-Way 10 7th February 2007 03:26 PM
LM3886 @ Parts Express!! troystg Chip Amps 6 6th April 2005 03:11 PM
parts express ! onis_uk Multi-Way 9 7th August 2004 01:56 AM
Page generated in 0.09589 seconds (75.49% PHP - 24.51% MySQL) with 10 queries
