Old 6th September 2004, 08:52 AM   #31
Pan is offline Pan  Sweden
There are foil inductors from several makers. These are considered the best aircore coils for serious speaker networks.
They come cheap and are easy to unroll and make a speaker cable of.
You can use the foils without insulation and connectors for the cleanest and fastest fix. If you like it you can insulate with plumbers teflon tape or cotton and put spades/bananas on them (not necessary though).
/Peter
Old 7th September 2004, 10:48 PM   #32
Hi Peter, thank you for your reply.
All,
Does anyone know of an Alphacore supplier (or other foil inductor manufacturer) in the UK. I've had a look on the net and haven't found any. I know Alpha ship internationally but the $35 makes the idea of buying a $15 inductor to experiment with less appealing !
Jon
Old 8th September 2004, 11:09 AM   #33
protos is offline protos  Greece
protos's Avatar
audiocom international or copper foil tape from rs
Old 8th September 2004, 01:22 PM   #34
promitheus's Avatar
Does anybody know, how to calculate the inductance of two foil conductors that laying on one another?
I am going to try to make a cable of 4 foils one on top of the other in a +-+- format. It should have very low inductance but high capacitance. The only problem is that the foil from the Mundorf coils isnīt insulated but there is a thin layer of isolation foil that is a bit bigger in width. My problem is to hold the whole thing together. Maybe running tape across the sides is a good idea.
Does anybody have an idea?
Old 8th September 2004, 02:34 PM   #35
jneutron's Avatar
#2...double stick tape.
#1...try this..it is for coaxial construction, so will depart from reality for small width foils or very large spacing..
Cheers, John
Old 8th September 2004, 03:26 PM   #36
jneutron's Avatar
Treat it as a double coaxial construct...
given W, width of the tape...
T, insulation thickness between the tapes..
DC, dielectric coeff of 2.7 (teflon, tefzel)
inner diameter is Dinner =W/3.1415
outer diameter is Douter =Dinner+(2*W)
inductance is = 60.96*LN(Douter/Dinner)
Kinda wish I coulda posted the picture instead..
For really far spacings, it reverts to the two wire Terman equation..
Cheers, John
Old 8th September 2004, 05:01 PM   #37
jneutron's Avatar
Ah, figured it out..the jpeg was too high....
Here it is..
While used for dual braid coax, it is applicable to flat conductors, as long as the spacing is small compared to the width..
It is inductance per foot vs diameter (width/pi), for various insulation thickness..so for 1 inch wide ribbons, use 1/pi for the diameter...Bad image, not very clear...let's try this:
<img src="http://forums.audioreview.com/attachment.php?attachmentid=660&stc=1">
Bah...that didn't work either..oh well, it's there if anyone wants a better image..
Cheers, John
F1 or F2 with MIT speaker cables? roscoeiii Pass Labs 1 13th July 2009 12:47 AM
cables for diy amps, preamps, and speaker cables ... paulspencer Solid State 5 3rd August 2004 07:14 AM
can I use OFC speaker cables jarthel Tubes / Valves 17 10th June 2003 09:03 PM
speaker cables dave k Multi-Way 7 25th May 2003 08:51 PM
Page generated in 0.08946 seconds (85.34% PHP - 14.66% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
