I was wondering whether there exist some data or even better software that would alow determining polar pattern for a driver of a given diameter as a function of frequency.
If so, could you please point me to it? Thank you, M |
#2 |
It doesn't work like that - dispersion being exactly related to diameter. Its far more complicate depending on cone / dome materials and profiles. |
#3 |
... pls look here
Arta and here http://www.fesb.hr/~mateljan/arta/Ap...r-Rev01Ger.pdf Regards Heinrich |
#4 |
#5 |
I have to agree with sreten on that.
The simulators don't allow for different cone shapes or contours of stiffness. A deep, rigid cone will have a narrower high freq. pattern than a curvilinear cone. Stiffening the apex will increase the upper limit, however it it stiffens too far up the apex, will beam it. I am doing right now, in fact. Geoff. edit. If the beam was down to 10 deg, is a flat baffle going to make it wider? Say 40 degrees. Be handy if it did. |
#6 |
Exactly, the only way is to measure in your own box.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#7 |
Thank you very much to everyone who replied.
Dear serten, Geoff H, and pinkmouse, I do realize that models have limitations. And some of the variables may even be of a second or lower order. I do not expect a quantitative analysis, more of a qualitative one, and insight, if you will. Staying with Richard W. Hamming's qoute "The purpose of computing is insight, not numbers." Kindest regardes, M |
#8 |
M,
The newest versions of my MathCad worksheets are going to show a polar plot of the driver in the enclosure. Right now it is set up as a free field polar plot but it will give the user some idea of how much sound energy is being reflected off the back or side walls and how directional the speaker is as a function of frequency. The polar plot accounts for the driver, port, or TL opening directivity as a function of size and shape and also the rectangular baffle edge sources. This is a work in progress and will continue to be developed. The OB worksheets were made available this weekend and hopefully a few more will follow every week or two depending on my time constraints at home. |
#9 |
Dear Martin,
thank you for the reply. I will have to dust-off my MathCad skills and try your worksheets. Kindest regards, M |
#10 |
Do a search for a tool called ARPE at the FRD consortium.
Alternatively I can send you a spreadsheet if you wish. It is based on The math at Art Ludwig's sound page. Art did a test of modeled vs. actual vs diameter based and found that shape matters very little in the farfield. Shape does matter for how the driver performs outside of the pistonic range, however....
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
| Wide polar pattern speakers via Diffusors | noodle_snacks | Multi-Way | 6 | 11th May 2012 07:47 PM |
| Pattern around tweeter... | Godzilla | Full Range | 6 | 9th December 2008 12:17 PM |
| Can I post this PCB pattern for the 25W Amp | r_s_dhar | Solid State | 2 | 15th July 2003 06:03 PM |
| Sub drivers: diameter vs. throw length? | newmz | Multi-Way | 2 | 18th April 2003 01:18 PM |
| Can I make a Non-Polar Electrolytic using two polar ones | PaulHilgeman | Parts | 6 | 10th February 2003 12:07 AM |
| Page generated in 0.11962 seconds (77.67% PHP - 22.33% MySQL) with 10 queries |
