#21 | |
when you ask for a driver's datasheet, most of the time it's not available you can see the list of the 2001 and 2002 product range, but only the 2003 datasheets are available :/ |
#22 |
I was looking for data for one of the older Audax drive units (HM170G0) and in one of those occasional moments of better-than-usual Google luck, found a .pdf file of one of their older catalogues - or at any rate one section of it.
http://www.ofgb.org/reference/Music/Audax/audaxcat.pdf It's quite a big file (several meg) but contains data and images for a lot of the older Audax range, including stuff no longer covered by their own Web site. May be of interest/value to others out there. Anyone know of any more Audax catalogues out there? Also I'm trying to find the publication date of the one linked above - does anyone know? (I need to reference it in some University work I'm doing....) Mike |
#23 |
The author of that website gives his Email address at the following page.
http://www.ofgb.org/ Try emailing him-he probably knows. I don't think that catalog is all that old.
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#24 |
Thanks kelticwizard, good thinking - I'll do that.
Mike |
#25 |
Im assuming from reading the thread that the problem is only being able to access datasheets in french.
If you click the english flag icon at the top of the homepage, you can access the datasheets in english. I do not know if this is already know, or if I have not understood the problem.
If it aint broke, don't fix it. If it is broke, fix it. If you can't fix it, take it apart and see how it "worked". |
#26 |
Additional driver info, many of them Audax, are available here:
http://www.hal-pc.org/~bwhitejr/drivers.txt YIOU can contact the aughors, two well-known audio engineers, at there home page: http://www.hal-pc.org/~bwhitejr/ Their speaker software is good, as well. However, do not use the Transmission Line program. It is experimental, based on faulty equations, and they later admitted the results did not match the real world. The other programs work fine, though.
| Marantz CD50 not functioning properly after mods | honinbou | Digital Source | 6 | 6th January 2008 10:52 PM |
| Reception On Tuning Scale Not Functioning Right. Need Help | 65blkbkgt | Car Audio | 2 | 15th July 2007 11:58 AM |
| WTB:Pink Triangle Da Capo (non-functioning) | Studley | Swap Meet | 2 | 28th January 2007 03:46 PM |
| what is the matter with e44 (French distributor of Audax etc.)? | capslock | Multi-Way | 1 | 30th November 2004 03:57 PM |
| Page generated in 0.09079 seconds (77.00% PHP - 23.00% MySQL) with 10 queries |
