Old 7th February 2007, 02:14 PM   #1
Default Produce frequency response curve
Hi all,
I'd like to produce a frequency response curve and I'm wonderrring what kind of noise to use. I know there are pink noise and white noise. Wich one should I use ?
Also can I perform the test in the middle of my listening room.
Do you have suggestion of an easy software to analyse spectrum ?
Thanks,
REALFLEO
Old 7th February 2007, 02:34 PM   #2
MarkMcK is offline MarkMcK  United States
There are many possibilities available. A search would have identified many.
Still, Auda's SpeakerWorkshop will allow quasi anechoic measurements using the MLS technique. Worth learning how to use it in the impulse response mode.
It is free and it works and can provide useful information.
I really can't recommend rta and continuous noise type systems. I can make sense out of them and separate speaker from room. Not too sure about others being able to do the same.
Mark
Which is the better response curve here.... Foxx510 Multi-Way 6 21st March 2007 10:46 AM
what does the response curve of a bass guitar speaker cab look like? Optical Instruments and Amps 11 2nd May 2005 12:11 PM
When making a response curve... Howard Subwoofers 8 8th November 2004 07:36 PM
Doubts on Phase Response and Frequency Response dumrum Multi-Way 11 5th April 2004 10:39 AM
What's a good response curve amoeba86 Multi-Way 29 18th July 2003 11:53 AM
Page generated in 0.08131 seconds (67.95% PHP - 32.05% MySQL) with 10 queries
