Hi everybody,
I builded a prototype of my vented 2way loudspeaker and want to mesure box losses. The book loudspeaker cookbook suggest to generate a impedance curve. Should I generate this curve with both the tweeter and driver connected ? Can I use this technique like I did when testing my driver: http://sound.westhost.com/tsp.htm Also, do you have suggestion of sites explaining a good technique to produce a frequency response curve with a mic ? Thanks, REALFLEO |
#2 |
It is best to measure driver impedance without a crossover connected, whether you are measuring free air or in a box.
I don't remember the formulas for loss offhand, it is in the LDC, but a measurement of impedance at a few key frequencies should be sufficient and any measurement of impedance should work.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#3 |
Are you saying that I should produce a impedance curve with just the driver directly connected ?
| help !! calculating switch losses | dead rat | Class D | 0 | 16th December 2008 03:33 PM |
| Impedance, the 10x rule, losses & bandwidth | awedio | Tubes / Valves | 10 | 17th August 2008 11:04 PM |
| Reverb insertion losses | ThSpeakerDude88 | Tubes / Valves | 5 | 28th January 2008 02:50 PM |
| Why i always have those losses in power using lower impedance loads? | destroyer X | Solid State | 12 | 5th June 2007 03:49 PM |
| diy modification on drivers to lower mechanical losses | capslock | Multi-Way | 28 | 16th October 2002 04:38 PM |
| Page generated in 0.08100 seconds (71.56% PHP - 28.44% MySQL) with 10 queries |
