Hello
I'm building a 2-way floorstanders for my father. Can someone help me with a simple but good crossover schematic? Midbass/Bass: Visaton W130S (8ohm) Tweeter: Visaton SC10N (8ohm) Cabinets are 950x250x170 mm Waiting your kind support! Ronald |
#2 |
I'm not sure that's a good combination; the peaks in the WS130S seem too close to the crossover point to me for a 'simple' crossover.
If you can use a larger driver, I'd go for the WS17E, which has a smoother and lower response. Pete McK |
#3 |
Oops, I didn't look closely at the tweeter response,
a crossover point of around 2Khz should be OK. You can design the crossover yourself by using an online crossover calculator such as : http://www.scriptsearch.com/cgi-bin/jump.cgi?ID=8420 using 10 ohms for the woofer impedance and 8 ohms for the tweeter (if you use 2KHz). I'd use a second order crossover because of the peaks. And you'll need an L Pad of around 3 dB for the tweeter. (I still think the WS17E would be a better driver though, & should only require a first order crossover). Pete McK |
| crossover help needed please | paul.42 | Multi-Way | 5 | 27th July 2007 06:13 PM |
| Visaton MHT12 crossover impedance...? | dynoPort | Multi-Way | 1 | 30th May 2007 11:56 AM |
| Crossover help needed | boostin1989 | Multi-Way | 9 | 13th July 2006 06:47 PM |
| Crossover help needed | nobody special | Multi-Way | 1 | 7th December 2004 05:42 PM |
| Crossover help needed! | shajan | Multi-Way | 2 | 18th February 2004 01:21 PM |
| Page generated in 0.07719 seconds (73.35% PHP - 26.65% MySQL) with 11 queries |
