Old 6th February 2007, 09:28 AM   #1
Default Using SoundEasy as the crossover ongoing
(I intend moving my primary source to losssles on PC; and doing some three way speakers).
It was suggested to me by someone who's used SE to measure speakers, the interface is a very steep learning curve, SE is not meant for long term use, and in particular IIRC you can't turn off non-ASIO kmixer.
In my limited research, reports differ on the effects of kmixer being not bit-perfect, depending on sound card/ drivers: kmixer can lose 3 dB of dynamic range and signal/ noise. Is it audible??
(also running the PC to play audio) Comments re using SE as the ongoing crossover?
Old 6th February 2007, 10:03 AM   #2
ergo is offline ergo  Estonia
I can not say about SE but LspCad can also emulate crossovers and has an ASIO support that works very stable at least with my Echo Layla24 for a 3 way speaker.
See www.ijdata.com
LspCad Pro in more expensive, so ...
Ergo
Old 6th February 2007, 01:35 PM   #3
dlr is offline dlr  United States
Default I've been using SE Digitial Filter for months now
I have a dedicated PC, 1.6M P4, that is on all the time running SoundEasy. Occasionally I swap out the MT box in the 3-way for another one, then load up its crossover, but that transition is the only time SE is not running. I haven't even put the PC on its own UPS, though I should, but power outages are rare for me.
Also, I have the Delta 410 card, but as long as the card works in SE, I don't see why there would be an issue with long term usage.
WTB: Soundeasy Ang Swap Meet 5 18th December 2008 12:53 AM
SoundEasy V14 FS idoru97214 Swap Meet 4 17th October 2007 05:11 PM
FS: SoundEasy 10 alexcd Swap Meet 3 18th June 2007 02:43 PM
SoundEasy crossover emulation ch83575 Multi-Way 3 26th August 2006 10:17 AM
Ongoing bass cab design problem TheoM Subwoofers 15 8th September 2004 04:24 AM
Page generated in 0.33671 seconds (-18.32% PHP - 118.32% MySQL) with 10 queries
